Avoid anything that's oilless.
Also depends what tools you want to run, an impact wrench doesn't need much but a DA sander needs plenty of CFM. Also check the CFM rating at pressure, some make lots @ 30 psi (OK for primer) but drop off drastically @90 psi where that sander runs. 7-10 CFM is usually plenty for home use.
