Author Topic: Compressor?  (Read 1051 times)
Offline 72vwtype2
  • Phil
Compressor?
« on: March 15, 2008, 09:22:09 AM »
What's a good all purpose type of compressor? I am looking to use it primarily for running some power tools and painting (primer).
Thanks.
1972 Kombi
1964 Vespa 150
Compressor?
« Reply #1 on: March 15, 2008, 09:50:59 AM »
Avoid anything that's oilless.
Also depends what tools you want to run, an impact wrench doesn't need much but a DA sander needs plenty of CFM. Also check the CFM rating at pressure, some make lots @ 30 psi (OK for primer) but drop off drastically @90 psi where that sander runs. 7-10 CFM is usually plenty for home use.
« Last Edit: March 15, 2008, 09:56:20 AM by BUSDADDY »
