Author Topic: Video Camera Mount In Car  (Read 1536 times)
« on: August 24, 2006, 05:55:28 PM »
has anyone made up a video camera mount in the car that clamps on and off there roll bar?figured i'd see what people have come up with before i do one.
also if you did make one what would you change on you desighn?
« Reply #1 on: August 24, 2006, 06:30:00 PM »
i'm pretty sure that geoff has done some in car camera work. hopefully he can help you out.
if you cant figure something out, i nominate myself to sit in the back seat and film one of your 11 second passes. :lol:
Offline Matt Davis
    • http://www.mattdavisracing.com
« Reply #2 on: August 24, 2006, 11:42:35 PM »
« Reply #3 on: August 25, 2006, 09:26:30 AM »
I made one about 6 years ago with a tri pod (it was a temp one) that tie straped into the car....it worked ok for a day at the track.  When I put the cage in a few years ago I made a mount between the driver and pass monted on the bar behind the seats.
« Reply #4 on: August 25, 2006, 09:28:13 AM »
matt thanks!! got some very good idea's from your pictures,man the video camera's sure are getting small these days.will make mine removable / clamp style as well
question?did you use the remote to operate it when you were in the car and did the video end up all shakey or good quality
« Last Edit: August 25, 2006, 09:29:30 AM by jim martin »
« Reply #5 on: August 25, 2006, 09:36:09 AM »
geoff i remember seeing that mount in your car when it was airspeed.wish i thought of it when i had my cage done
« Reply #6 on: August 29, 2006, 11:37:55 AM »
A guy I icerace with has one mounted in his car. He is using a couple small vibration dampeners under the camera to reduce the vibrations. It works really well especially considering that iceracing is so violent with rough track surfaces and such. I will ask him where he got them next time I see him.
Offline Matt Davis
« Reply #7 on: August 31, 2006, 04:06:57 AM »
http://www.figmeyerracing.com/media/Sac%20...20round%202.wmv
Here ya go Jim.
« Reply #8 on: August 31, 2006, 06:01:53 PM »
thanks matt,that turned out great
