Author Topic: What Is Best Carb For?  (Read 6312 times)
« on: August 16, 2006, 11:21:38 PM »
dual solex 34s, Dual kads 40s. dual Dell 36s ?
« Reply #1 on: August 17, 2006, 07:40:35 AM »
44 IDF'a or 45 DRLA'a - or larger.
Offline 1blk66
« Reply #2 on: August 17, 2006, 10:22:10 AM »
« Reply #3 on: August 17, 2006, 12:24:57 PM »
Since you are planning really low CR, and a tiny cam, you need 40 DRLAs.  The dual single bbls will kill the engine combo.
« Reply #4 on: August 17, 2006, 01:24:43 PM »
Could I get dual Dellortos 36s to work that configurations?
« Reply #5 on: August 18, 2006, 11:08:54 AM »
They'll work a lot better than dual single bbl carbs.  They will restrict the hp a bit, but they will give great throttle response and great mileage.  Driving will be like a modern FI car once the carbs are set-up properly.
« Reply #6 on: August 18, 2006, 11:17:33 AM »
You so need these carb's  :rockon:
http://cgi.ebay.com/ebaymotors/gene-berg-w...sspagenameZWDVW
IMO, 44 DCNFs are kinda big for this engine.
Also, Weber specifically states that DCNFs should be installed with the throttle shafts perpendicular to the length of the car.  IE. not in a VW.
Offline surgerypending
« Reply #7 on: August 19, 2006, 09:06:59 AM »
In my last car I had a 2110 with 45 Dells....they worked very well....low maintance and would pass aircare no problems!
« Reply #8 on: August 19, 2006, 10:55:42 AM »
Great to hear about air care. Who tuned them?
Emilio
« Reply #9 on: August 19, 2006, 12:36:34 PM »
I tuned them myself!
« Reply #10 on: August 19, 2006, 10:55:45 PM »
Yes , when mounted in our VW's  the float bowl will dump fuel down the throats and/or starve the main circuit during hard cornering
« Reply #11 on: August 20, 2006, 12:14:32 AM »
However, those that have run DCNFs report that they LOVE these carbs.  I have never tried DCNFs, Hans has.
« Reply #12 on: August 20, 2006, 11:22:40 PM »
Yes I love mine too(except for that cornering thing)  but the main attraction is that they fit in a type 3(sort of)
Those DCNF's above look like they have Type 3 manifolds.  That will not work in a beetle. You would need to find Beetle DCNF  manifolds.
