Author Topic: Dual Weber 34 Ict's  (Read 4861 times)
Offline kubelguy
  • The road to success is always under construction
Dual Weber 34 Ict's
« on: May 14, 2006, 05:38:24 PM »
Will a stock fuel pump deliver to a pair of dual weber 34 ict carbs?
'68 deluxe bus/sunroof
'57  beetle
Dual Weber 34 Ict's
« Reply #1 on: May 14, 2006, 07:59:10 PM »
it should be fine
they can put out quite a bit actually i know that a car bruce was working on went 12.99 on a stock pump
Dual Weber 34 Ict's
« Reply #2 on: May 15, 2006, 10:04:57 AM »
it should be fine
12.997 to be exact.  It would have gone faster with close ratio gears.
The stock pump will provide much more volume than you need.
Offline flat4
Dual Weber 34 Ict's
« Reply #3 on: May 15, 2006, 10:26:25 AM »
What kind of RPM is the stock pump good till?
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Dual Weber 34 Ict's
« Reply #4 on: May 15, 2006, 01:35:12 PM »
No tach in that car.  I have spun an engine with a stock pump up to 7800rpm.  I don't know at what RPM you will float the pump's spring.  IMO it doesn't matter that much since you don't spend a lot of time at super high rpms, and there's no damage to anything when you float the pump.
Dual Weber 34 Ict's
« Reply #5 on: May 15, 2006, 09:33:28 PM »
it should be fine
it could have been a 12.996 if it werent for the helmet issues.  ;)
Dual Weber 34 Ict's
« Reply #6 on: May 16, 2006, 10:00:09 AM »
Ahhh Silas, you're just jealous you didn't have the owner of a 12 sec car hand you the keys to his car and say beat the f##k out of it at the track.
