Author Topic: Vert Beetle Bodywork  (Read 4569 times)
Offline kubelguy
  • The road to success is always under construction
« on: May 14, 2006, 04:47:25 PM »
Do regular beetle pan replacements fit verts?
« Last Edit: May 14, 2006, 04:54:20 PM by kubelguy »
'68 deluxe bus/sunroof
'57  beetle
Offline 72vwtype2
  • Phil
« Reply #1 on: May 14, 2006, 06:20:44 PM »
I am not an expert on verts. But I believe vert pans are heavily reinforced, since there is no roof.  A regular pan would fit but you would have some serious issues with trying to keep the car from twisting itself (i.e. no integrity).
1972 Kombi
1964 Vespa 150
Offline ScreamnStroker
« Reply #2 on: May 14, 2006, 06:32:51 PM »
When I replaced the floor pans on the 63 vert they were regular sedan beetle pan halfs, I just ground off the jack post so it would clear the Convertable support rails
« Last Edit: May 14, 2006, 07:45:59 PM by ScreamnStroker »
Offline kubelguy
« Reply #3 on: May 14, 2006, 08:09:54 PM »
So you could fit new pan halfs inbetween the reenforcement channel of the vert?It looks like the reenforcement is soft too.The body is twisting or flexing and the doors are going in and out of alignment,being wider at the top of the door.
'57  beetle
Offline Mowser
« Reply #4 on: May 14, 2006, 08:23:39 PM »
Contact Slammedbus on this forum.  He just finished doing the full on the '63 vert pictured above.  He would be able to aid you in your quest.
« Reply #5 on: May 14, 2006, 09:10:27 PM »
From what I've seen the pans are all the same it's just that the vert's use the extra reinforcement rail underneath.
Offline Daniel
Re: Vert Beetle Bodywork
« Reply #6 on: June 30, 2009, 10:17:24 PM »
same pan
all support is on the rail
daniel
« Reply #7 on: July 05, 2009, 07:30:26 AM »
Same pan you will just need to trim the edges back about 3/8" so they will clear the support rails when the shell gets dropped on.
« Reply #8 on: July 06, 2009, 09:04:43 AM »
you know I think they are the same.
Offline Daniel
« Reply #9 on: July 18, 2009, 05:59:04 PM »
I just completed 2 convertible resto.
same pan just have to remove /modify jack stand surport.
Daniel
