Vert Beetle Bodywork
Topic: Vert Beetle Bodywork (Read 7417 times)
kubelguy
The road to success is always under construction
May 14, 2006, 04:47:25 PM »
Do regular beetle pan replacements fit verts?
Last Edit: May 14, 2006, 04:54:20 PM by kubelguy
'68 deluxe bus/sunroof
'57 beetle
72vwtype2
Phil
Still searching....1972 Single or Double Cab
May 14, 2006, 06:20:44 PM »
I am not an expert on verts. But I believe vert pans are heavily reinforced, since there is no roof. A regular pan would fit but you would have some serious issues with trying to keep the car from twisting itself (i.e. no integrity).
1972 Kombi
1964 Vespa 150
ScreamnStroker
May 14, 2006, 06:32:51 PM »
When I replaced the floor pans on the 63 vert they were regular sedan beetle pan halfs, I just ground off the jack post so it would clear the Convertable support rails
Last Edit: May 14, 2006, 07:45:59 PM by ScreamnStroker
kubelguy
May 14, 2006, 08:09:54 PM »
So you could fit new pan halfs inbetween the reenforcement channel of the vert?It looks like the reenforcement is soft too.The body is twisting or flexing and the doors are going in and out of alignment,being wider at the top of the door.
'57 beetle
Mowser
"You know, Hobbes, some days even my lucky rocketship underpants don't help. " Calvin
May 14, 2006, 08:23:39 PM »
Contact Slammedbus on this forum. He just finished doing the full on the '63 vert pictured above. He would be able to aid you in your quest.
BUSDADDY
Like potato chips, you can't have just one
May 14, 2006, 09:10:27 PM »
From what I've seen the pans are all the same it's just that the vert's use the extra reinforcement rail underneath.
Daniel
Re: Vert Beetle Bodywork
June 30, 2009, 10:17:24 PM »
same pan
all support is on the rail
daniel
slammedbus
Reply #7 on:
July 05, 2009, 07:30:26 AM »
Same pan you will just need to trim the edges back about 3/8" so they will clear the support rails when the shell gets dropped on.
Chris
Car.
Reply #8 on:
July 06, 2009, 09:04:43 AM »
you know I think they are the same.
Daniel
Reply #9 on:
July 18, 2009, 05:59:04 PM »
I just completed 2 convertible resto.
same pan just have to remove /modify jack stand surport.
Daniel
