Author Topic: Engine Cover Type 1  (Read 1384 times)
Offline pockets
Engine Cover Type 1
« on: March 23, 2006, 10:45:39 AM »
Now I hate to ask this question as I feel dumber than a stick, but here goes anyways.
How do you install the spring that holds up the engine cover on a 1968 type1? which way does the coil go?
Ubique
1968 bug
Offline Bug Maniac
Engine Cover Type 1
« Reply #1 on: March 23, 2006, 11:42:21 AM »
Dont feel dumb that's one of the reasons for the forum, sorry I cant help, I'm sure one of the guys will be able to tell ya
Cheers :rockon:
Engine Cover Type 1
« Reply #2 on: March 23, 2006, 01:28:44 PM »
Here are the tools you will need. Two strong thums and some eye protection.
Instal the rounded part into the notch under the rear window then push as hard as you can and slip one of the ends into the hole on the lid. Then using those strong thumbs push the other end into the second hole.
Maybe not the best discription but it should help.
Offline pockets
Engine Cover Type 1
« Reply #3 on: March 23, 2006, 02:23:47 PM »
Got it coil up  duhhh     Thanks
Ubique
1968 bug
Engine Cover Type 1
« Reply #4 on: March 23, 2006, 04:49:51 PM »
if your thumbs aren't strong enough , get geoff's friend \" MITTINS\" to help you out.
