Author Topic: Port-a-walls?  (Read 2032 times)
Port-a-walls?
« on: February 01, 2006, 09:24:50 PM »
Any ideas where I can find a set of 15 inch port-a-walls locally? And any hints on how to install them?
Port-a-walls?
« Reply #1 on: February 01, 2006, 09:57:55 PM »
didnt you already post this? I did some reading and it says they dont work well on radials, that they are designed for bias ply, but check with Geoff or Jim I think they said previously they could get them.
« Last Edit: February 01, 2006, 10:02:09 PM by 1976BUS »
Port-a-walls?
« Reply #2 on: February 02, 2006, 09:18:35 AM »
Pretty sure I didn't post this before. Maybe I'm smoking crack. Anyways think there are any adverse affects or that it just might not work as well? I'm sure a bunch of other people have done it before me..
Port-a-walls?
« Reply #3 on: February 02, 2006, 09:21:01 AM »
everything I have ever read says that they tend to stick out from the sidewalls, but someone around here has some....
maybe they would be better to answer this.
Port-a-walls?
« Reply #4 on: February 02, 2006, 09:23:33 AM »
I read that but that was on Temporary size tires. I actually run decent size rubber on my machine:P
Port-a-walls?
« Reply #5 on: February 02, 2006, 09:37:08 AM »
They work fine on Radials, depending on the sidewall size. The ones you want (best) are the Atlas brand. They have been hard to find the last few years. There are some other brands at the new KMS autoparts store next to KMS in Coquitlam.
G.
Port-a-walls?
« Reply #6 on: February 02, 2006, 01:03:30 PM »
KMS tools is out of 15's. The search is on..
Port-a-walls?
« Reply #7 on: February 02, 2006, 03:46:28 PM »
http://www.airspeedparts.com/community-for...=ST&f=24&t=7426
you're on crack.
now be a good little addict and share with the class.  B)
« Last Edit: February 02, 2006, 03:47:45 PM by silas »
Offline Mowser
Port-a-walls?
« Reply #8 on: February 02, 2006, 04:00:46 PM »
ROFLMAO :lol:  :lol:
Port-a-walls?
« Reply #9 on: February 03, 2006, 12:55:41 AM »
Yeah but that thread went no where... Point being?
Port-a-walls?
« Reply #10 on: February 03, 2006, 03:12:48 PM »
do i have to spell it out for you?
you said you didnt, i called you out and proved it by posting a link.
besides, if everyone here started double posting just because their first post got no response, this forum would be a mess.
point being...if you make a mess...remember where you leave it so you can clean it up.
Port-a-walls?
« Reply #11 on: February 04, 2006, 01:00:36 AM »
I don't see the logic.
I posted up a wanted to buy add. I got no responses. I go to another section of the forum... Ask a relavent VW related question.
Okay so I flubbed up. I don't live on these forums..
But whatever I won't lose any sleep over it.
Port-a-walls?
« Reply #12 on: February 04, 2006, 09:40:12 PM »
Posted on Feb 4 2006, 01:00 AM
isnt 1am way past your bedtime tho?
Port-a-walls?
« Reply #13 on: February 04, 2006, 09:43:27 PM »
I won't even start to begin the tale of the last two weeks. But yeah I probably should of been sleeping rather then working on my waterpumper.
