Author Topic: Type 1 Thermostat  (Read 1183 times)
Offline shovel80
Type 1 Thermostat
« on: January 21, 2006, 06:51:16 AM »
What can a guy do get a new thermostat for my 1600 mine is shot and is fully extended when cold and has no movement. I here replacments are hard to come by ?
Thanks Dave
Type 1 Thermostat
« Reply #1 on: January 21, 2006, 12:47:16 PM »
There does exist a replacement for the brass bellows.  You have to change the vertical rod and thermostat bracket.
Airspeed should be able to supply you with that.
Type 1 Thermostat
« Reply #2 on: January 21, 2006, 05:22:10 PM »
I sourced one in Salmon arm locally go the last one .Can't believe they are not making them anymore there is a reprosomeone should step up and do  :( Good luck def try airspeed for the aftermarket one and instrucs  :)
Type 1 Thermostat
« Reply #3 on: January 21, 2006, 06:18:45 PM »
I have a couple original VW used ones if you can't find any local.
Offline shovel80
Type 1 Thermostat
« Reply #4 on: January 26, 2006, 09:03:49 PM »
Thanks a lot
