Author Topic: Gas Heaters  (Read 4717 times)
Offline rustybus
Gas Heaters
« on: December 02, 2005, 01:49:13 PM »
Who fixes them ? How can you test them before installing them?
Gas Heaters
« Reply #1 on: December 02, 2005, 01:58:46 PM »
Bruce T is good with them, he should see this post.
Gas Heaters
« Reply #2 on: December 03, 2005, 12:29:15 PM »
Connect up a piece of hose to the feed of the pump and stick the other end into a gas can.  Apply 12V to the big black wire.  Ground the brown wire and turn it on to see what it does.
Put your leads from your volt meter on the glow plug to see if it gets 4V.
Don't put a long hose on the exhaust to try to vent it outside.  The heater won't work then.
What model is the heater?  Pic?
« Last Edit: December 03, 2005, 12:31:48 PM by Bruce »
Offline kit
Gas Heaters
« Reply #3 on: December 03, 2005, 12:38:21 PM »
need some one to come and install this heater dont feel like messin with it , bn2 , everything therewill pay cash
Offline rustybus
Gas Heaters
« Reply #4 on: December 03, 2005, 04:10:13 PM »
Bruce
Thanks for the input . It's a 6 volt b2 that I wanna check . But I can also check the others that I do have
Chris
Gas Heaters
« Reply #5 on: December 03, 2005, 05:47:47 PM »
Bruce
Chris
B2s are very simple to work on.
You will have to clean out the fuel system.  That grey steel block up by the glow plug with the 3 hoses connected to it contains 3 fuel jets.  It is probably plugged.  Take it all apart and clean all the parts.  Also take apart the sediment bowl and clean it out.
Check every wire connection.  Tighten up all the slotted set screws that clamp onto the wires.
Put power to it before adding fuel.  The fan should come on right away, and you should hear a  clicking that's the pump.  Dry, it will click 3-4 times a second.  Then put your volt meter on the glow plug.  It should be getting 4V (for a 12V heater).  Your 6V heater might be the same since I don't think there's a 6V glow plug.  You can try to measure the glow plug's resistance, but it can measure good when they are bad.  The best way is to wire up an ammeter in series to it.  I think the glow plug draws 5-10 amps.  You can take out the glow plug and inspect the element.  If it is broken, you need a new one.  I think Geoff has them.
« Last Edit: December 03, 2005, 05:51:42 PM by Bruce »
