Author Topic: Just Got Em !  (Read 1706 times)
Offline btljuce
Just Got Em !
« on: August 31, 2005, 09:15:16 PM »
i got the schubecks today and damn,....  are they ever nice. i don't know if they are 560.00 usd nice, but... damn are they nice !!!!
Der Kleiner Rennwagens
 56 rag oval now  2332 !!
 56 wolfsburg kombi
Just Got Em !
« Reply #1 on: September 01, 2005, 08:59:38 AM »
Ok for us speed iliterate lets see some pics and maybe some tech info in lamens terms as to why they are all the rage please I'm intresred  :huh:
Thank
Offline Trevor P
Just Got Em !
« Reply #2 on: September 01, 2005, 11:22:33 AM »
Wow, that was quick, didn't you just order them the other day.  :blink:
Now put 'em in and get that 56 doing 12's before the season is over! :D
'53 Barndoor single cab
'70 911T
Offline btljuce
Just Got Em !
« Reply #3 on: September 01, 2005, 08:15:29 PM »
the lifters are made of a composite material .I believe they are silicon nitride ( or carbide sorry can't fully remember) but this means is no more cam break in. also these lifters do not wear out. you can run any cam new or used,you can also re-use these lifters on any cam. they do not pattern. fire up and go !!!!!  they are also lighter than stock !  the only problem is choking back the money to buy them !! now my wallet is flat , instead of my cam ! :lol:
« Last Edit: September 01, 2005, 08:26:27 PM by btljuce »
 56 wolfsburg kombi
Just Got Em !
« Reply #4 on: September 01, 2005, 08:17:47 PM »
But you'll never (theoretically) need to buy lifters again so in the long run you'll save...
Offline btljuce
Just Got Em !
« Reply #5 on: September 01, 2005, 08:21:52 PM »
very true james, very true.  and  at 560.00 usd a set, you hope to hell you don't break one !!!! :lol:
« Last Edit: September 01, 2005, 08:25:36 PM by btljuce »
 56 wolfsburg kombi
Just Got Em !
« Reply #6 on: September 01, 2005, 09:38:01 PM »
OK so last lifters you'll need but what about the cam?
No cam wear? Some cam wear?  Whats the word?
Offline btljuce
Just Got Em !
« Reply #7 on: September 01, 2005, 09:51:08 PM »
supposedly no cam wear ! these are the solution to flat cams. from what i hear anyway. ask tom h about em. he has a couple sets.i think kroc has a set as well . i'm sure they will chime in sometime !? B)
 56 wolfsburg kombi
Offline jim martin
Just Got Em !
« Reply #8 on: September 01, 2005, 11:35:15 PM »
i'm part of the gang now as well.seams i needed to build my new motor earlier than thought.
did you bush your mag case?
seams to be a issue,if you phone schubecks they will tell you its not needed,LN engineering says you should do it because jake raby says so.
Offline btljuce
Just Got Em !
« Reply #9 on: September 02, 2005, 10:01:50 AM »
actually jim ,i'm using the aluminum case. and i 'm looking at my invoice here, and it says in bold letters \"WE DO NOT WARRANTY FLAT LIFTERS THAT ARE RUN IN LIFTER BORES WITH BRONZE BUSHINGS \" so i won't get mine done.
 56 wolfsburg kombi
