Author Topic: Turbo Singleport Movie  (Read 1545 times)
Billyisgr8
« on: August 21, 2005, 08:09:20 PM »
Here she is, and it died right at the end, incase you were wondering.
http://www.zippyvideos.com/105295016911455.html
Specs again are....
bugpack cam  284 duration  1.1 rockers
D shape ported heads with port diameter of approx 34 mm...  35 x 32 valves
T3 turbo  60 trim .63 exhaust
1 1/2\" exhaust
2\" SU carb
Still need to play with timing, and getting the right taper on the needle.
« Last Edit: August 21, 2005, 08:53:21 PM by Billyisgr8 »
« Reply #1 on: August 21, 2005, 09:00:38 PM »
Way to go Kevin
Billyisgr8
« Reply #2 on: August 21, 2005, 10:16:20 PM »
hmm after watching the movie from the posted link and the original, the host web server has taken some of the clarity and sound away.  I guess that is what happens when it is for free. The original is much better.
« Reply #3 on: August 22, 2005, 09:12:11 AM »
Good to see it running Kevin.......But what the F$'*k IS WITH THE TAIL LIGHTS?
Billyisgr8
« Reply #4 on: August 22, 2005, 09:35:48 AM »
That was only for having it ready to race at mission so the car could be street legal, and I could drive it on Saturday on the street.
Billyisgr8
« Reply #5 on: September 03, 2005, 09:08:21 AM »
Here is a shot of my engine, and heads .  I found out living in Sicamous does have it's disadvantages.  The Air liquid vender just closed within a month before I did all of this so now I have to go to Salmon Arm which sucks.  Welding up everything on whichever weekend it was I went from Mig welding with gas, to mig welding with flux core to gas welding.  I should have just gas welded everything, much nicer and cleaner with the beads, and less air leaks when testing.  Everything must be tight fitting though, with the mig it is easier to just fill in gaps, but with the mig I was chasing pin holes all over and over and over.  Gas was easy to fill pin holes once and they were done..
The carb is getting closer to being good with the air/fuel mixture, I can atleast rev it to 6000 rpm now.  Profiling the main needle to the proper taper is a pain, but will be well worth it once done, I'm not looking forward to doing this all over once I start with the boost on the road.
« Last Edit: September 03, 2005, 09:13:23 AM by Billyisgr8 »
« Reply #6 on: September 03, 2005, 10:10:29 AM »
Kevin Kelowna ? are  you  run it this year man ? fill  us in  :blink:
