VW Club Corner
Beam Issue
Topic: Beam Issue (Read 3050 times)
rustybus
Beam Issue
May 09, 2005, 10:02:20 AM »
Are drum brake beams the same as disc brake beams ? can I put the disc brake set up on my drum brake beam?
Chris
Chris
Car.
Beam Issue
May 09, 2005, 10:15:41 AM »
generally its just determining whether or not its king & link or balljoint....
rustybus
Beam Issue
May 09, 2005, 10:19:14 AM »
Sorry I forgot to mention that they are both ball joint :blush:
Chris
Mike Scott
Beam Issue
May 09, 2005, 10:24:14 AM »
No difference in the beams, but you do need disc mount spindles to attach your calipers to.
, If you dont already have them
Mike
Last Edit: May 09, 2005, 01:28:37 PM by sick-d-three
Beam Issue
May 09, 2005, 07:40:03 PM »
yup, what he said. you need disc brake spindles to run disc brakes. check the bottom of this list...
http://www.airspeedparts.com/catalog/index...e1b1b3dbf081e55
tho, i'd suggest getting lowered disc spindles for disc brakes. then get some adjusters in your beam and you can drop the nose to the height you like.
VW Club Corner
Beam Issue
