Author Topic: Beam Issue  (Read 4823 times)
Offline rustybus
Beam Issue
« on: May 09, 2005, 10:02:20 AM »
Are drum brake beams the same as disc brake beams ? can I put the disc brake set up on my drum brake beam?
Chris
Beam Issue
« Reply #1 on: May 09, 2005, 10:15:41 AM »
generally its just determining whether or not its king & link or balljoint....
Offline rustybus
Beam Issue
« Reply #2 on: May 09, 2005, 10:19:14 AM »
Sorry I forgot to mention that they are both ball joint :blush:
Chris
Offline Mike Scott
Beam Issue
« Reply #3 on: May 09, 2005, 10:24:14 AM »
No difference in the beams, but you do need disc mount spindles to attach your calipers to.  ;) , If you dont already have them
Mike
« Last Edit: May 09, 2005, 01:28:37 PM by sick-d-three »
Beam Issue
« Reply #4 on: May 09, 2005, 07:40:03 PM »
yup, what he said. you need disc brake spindles to run disc brakes. check the bottom of this list...
http://www.airspeedparts.com/catalog/index...e1b1b3dbf081e55
tho, i'd suggest getting lowered disc spindles for disc brakes. then get some adjusters in your beam and you can drop the nose to the height you like.
