Author Topic: Split Bus Ignition?  (Read 1069 times)
Offline el_flechador
Split Bus Ignition?
« on: April 19, 2005, 08:04:24 PM »
Does anyone know if there is a trick to fitting the ignition barrel on a split bus. Mine seems to foul at the rear when in the correct position. I found a key and barrel lying under the dash when i got my van  so iam presuming it is the one that originally came from it as i have nothing to compare it too. (I realise know that it might just me some random bits) but thought i would ask incase there was a particular(and probably)obvious trick that iam overlooking??
Split Bus Ignition?
« Reply #1 on: April 20, 2005, 06:35:13 PM »
Check your e-mail  :)
Split Bus Ignition?
« Reply #2 on: April 20, 2005, 07:29:48 PM »
Cheers for the advice
