Author Topic: Need Some Advice  (Read 2156 times)
Offline Swartz
Need Some Advice
« on: January 30, 2005, 08:41:31 PM »
hey, would like to hear some of your thoughts on this company... www.jscvwparts.com i was looking at the 1835cc and 1914cc turnkey motors...any thoughts would be great
thanks
Everything takes time
Need Some Advice
« Reply #1 on: January 30, 2005, 08:46:02 PM »
web address doesnt work for me
Need Some Advice
« Reply #2 on: January 30, 2005, 09:40:15 PM »
I don't know any thing about this company but I personally would not recomend buying an 1835 or anything with a 92mm P&C kit. Go 1775 or 1914 (90.5 or 94's)
Offline Swartz
Need Some Advice
« Reply #3 on: January 30, 2005, 10:10:24 PM »
Need Some Advice
« Reply #4 on: January 31, 2005, 12:36:40 PM »
I haven't heard about it either.  I'm sure you could have a motor built also instead of buying turnkey or a long block.
Call up airspeed and see who they would recommend to build your engine (Darren maybe?).
Stephan
« Last Edit: January 31, 2005, 12:41:14 PM by Stephan Schmidt »
Offline Swartz
Need Some Advice
« Reply #5 on: January 31, 2005, 07:08:26 PM »
how much would i be looking at to get a similar motor to that 1914 build...that one converted to $2700 canadian....and also what kind of power/reliability can i expect from it?
Offline Chad M
  • Custom Title
Need Some Advice
« Reply #6 on: February 01, 2005, 01:01:31 PM »
All I know is that if you drive your car like a race car, it will last like a race car.  Just about anything can be babied and made to last a long time.  The only problem, the bigger the \"baby\" the harder you will want to spank 'er...
Need Some Advice
« Reply #7 on: February 01, 2005, 05:31:48 PM »
what are the specs on that motor? remember, it might be that $$ in conversion, but shipping won't be nice :(
what do you want to do with the car? highway? cruise? race? What is your budget?
you need to figure out a plan for the car, and then people can suggest motor combos if you know what you want.
I'd suggest this:
1914 cc
CW 69 mm crank
94mm P&C's
engle 110 cam
balanced rods
DP heads lightly ported (maybe some 041's, or 044's - 40x35.5)
dual 40 mm kadrons or 40mm IDF's or Dellortos
header with a single/dual quiet pack
009 distributer with petronix
stock fuel pump
Very reliable, real nice power, and fun to drive.
Stephan
« Last Edit: February 01, 2005, 05:32:59 PM by Stephan Schmidt »
Need Some Advice
« Reply #8 on: February 01, 2005, 05:45:25 PM »
I'd suggest this:
1914 cc
CW 69 mm crank
94mm P&C's
engle 110 cam
balanced rods
stock fuel pump
Stephan
If your name is James.... :wacko:
Offline Swartz
Need Some Advice
« Reply #9 on: February 01, 2005, 05:49:40 PM »
it has to get me to work and back 6 days a week(10km each way) for a couple months while the weather is nice....and than also a weekend warrior i guess...i dont want it to be a drag only car but i most likely will run it. I dont really have a budget because ill just save as long as i need till i get what i want. I always plan on going to airspeed to talk to someone but i always work the same hours as them!!!! they should open up on sundays! :rockon:
Need Some Advice
« Reply #10 on: February 01, 2005, 06:14:23 PM »
haha...:P
yah, that combo would be reliable.
Shane had a 65 beetle in it with a 1776 and dual kadrons and he ran 15.XX in the 1.4 mile...what was the time again shane?
anyways, for what the motor was, it was an impressive time!
Stephan
Need Some Advice
« Reply #11 on: February 03, 2005, 11:28:02 AM »
I have a 2275 cc that I am selling.
$4000 turnkey, and $3000 without carbs.
Stephan
