Author Topic: Mig Welder Help  (Read 1863 times)
Offline slugbug
Mig Welder Help
« on: October 11, 2004, 02:25:58 PM »
Looking to buy a Mig Welder and need some feedback. Seen a SIP MIGMATE 35 - 100 A Portable Migwelder  on EBay,click me but I can't find any info on it. Need to know if it will work with flux core wire(gasless),or does it need shielding gas bottle for it to work? Don't have a model number for it so google not much help.
« Last Edit: October 11, 2004, 02:36:45 PM by slugbug »
[/a]
Mig Welder Help
« Reply #1 on: October 11, 2004, 02:35:17 PM »
Link doesn't work, but most welders can change polarity for flux-core or shielding gas. I have found nicer welds with shielding gas.
Offline slugbug
Mig Welder Help
« Reply #2 on: October 11, 2004, 02:37:26 PM »
I fixed the link
[/a]
Offline Scratchy
Mig Welder Help
« Reply #3 on: October 12, 2004, 08:56:59 AM »
You'll be much happier with the results if you use gas.
Also, you'll want a bare minimum of 120A - preferably 135A. Otherwise you won't be able to weld anything over 1/8th\".
Even if it's only for sheet metal, there will always a job that comes along, where you have to weld something heavier. 100A just does not have the penetration to weld anything substantial.
Just my 2 cents (I have a 120A - Cale had a 100A).
Offline HeliMike
Mig Welder Help
« Reply #4 on: October 12, 2004, 11:21:26 AM »
Don't know how much you're looking to spend but here's something to think about:
Clarke, (Made in Italy-not Taiwan)
Model #130EN (130A,110V Mig/Flux)
2 year warranty, 10 year on transformer.
4 heat settings,variable wire speed settings.
Fan-cooled. Holds 2 or 11lb wire roll.
Welding capacity is 3/16's plate (I've seen 1/4\" though)
Factory says duty cycle is 30% but I know it's more first-hand.
Thermo shut-off in case of overheating.
Comes ready for flux-core but can be converted to gas VERY easily.
Comes with wire and tips.
*** BRAND NEW-NEVER USED ***
Receipt suppllied - $385 (+ tax) for welder,
$60 (+tax) for gas conversion kit (regulator,gas-line,tips,wire)
It uses a \"Tweco\" torch assembly so it's easy to find parts for as well.
All you have to do is supply a bottle and power and you're off to the races.
Don't know where you are but assuming you're local I can arrange a drop off.
I can also ship if need be.
Although Clarke is not a \"Industrial Grade\" (ie: Lincoln,Miller) welder there's a shit-load of them out there with excellent success. I sold the same model to my brother (for his home shop) who's a professional welder/fabricator and he loves it and can EASILY weld anything he needs with it. We've narrowed beams,welded new pan-heads, done heater channels, and built a trailer with it and it keeps on going with no problems at all.
Also available in a 220V, 180A version as well.
I wouldn't try to peddle \"shit\" onto other VW people. I can guarantee you'll be impressed with this welder. Out of the hundreds we sell here across Canada we have had MAYBE a handfull of problems but they're easily fixed by shipping the parts directly to you or the service centre if need be.
**EDIT**
9 times out of 10 the problem is the operator and not the machine!
Usually just inexperience that leads to something minor like a gas shield or tip.
I forgot to add that in there.
Cheers!
Mike :mullet:
If anybody IS interested in any welders I can work out trades for VW stuff.
I'm looking for a set 36 or 40 Dell's as well as T3 intakes and cleaners.
Also, these are 100% lagitimate.
« Last Edit: October 12, 2004, 04:16:57 PM by Gutterslug »
67 Sunroof Beetle
Offline slugbug
Mig Welder Help
« Reply #5 on: October 12, 2004, 05:24:53 PM »
Sent you a PM Gutterslug  :)
« Last Edit: October 13, 2004, 07:09:59 AM by slugbug »
[/a]
Offline HeliMike
Mig Welder Help
« Reply #6 on: October 13, 2004, 10:02:11 AM »
Ditto :mullet:
67 Sunroof Beetle
