Author Topic: New Fuse Box - No Signals/brake Lights  (Read 11256 times)
« on: August 02, 2004, 05:07:09 PM »
Ok, I've installed a new aftermarket fuse box in my 66. Everything is working except for my turn signals and brake lights. I have hazards, driving lights, headlights and all dash lights.
One noticable difference is that the after market places fuses (the 2 end red fuses) at the drivers side of the panel instead of one on either end. I had to extend a couple of wires to accomadate this. Anyone smart out there that can help me out :)
« Reply #1 on: August 02, 2004, 05:19:33 PM »
Any loose wires on the switches, check your turn signal relay as well. Should be pretty obvious problem, if all you did was swap the fuse box, unless of course your headlights are now your turn signals and vice versa :)
« Reply #2 on: August 02, 2004, 05:27:33 PM »
I've checked all the connections, I would think if the relay was shot then the hazards wouldn't work.
Like I said everything else works except the brake lights and turn signals.
« Reply #3 on: August 02, 2004, 06:00:05 PM »
check your grounds, your brake lights and turn signals are the probably the same, if your stuck I could come by and take a look, are the fuses good? what type of fuse? glass?
« Last Edit: August 02, 2004, 06:01:13 PM by 1976BUS »
Offline Mowser
« Reply #4 on: August 02, 2004, 11:42:01 PM »
If memory serves..... VW has an odd way of using signal lights.  Check all the wires again that come off of the collumn.  Me thinks you inadvertantly hooked up one wrong.  I could tell right away if I were there..... sorry bud.  The last wiring nightmare I worked on was SlammedBus's Notchback.  I imagine they are about the same though.....  When in doubt find a copy of the wiring diagram for your car that has colour coding on it.  If you have hazards but no signals then it's a signal problem from the collumn.  The hazards are direct to the relay but the column goes through the fuse box.  Again....... IF MEMORY SERVES!!!
Mo
Offline Black-Back
« Reply #5 on: August 03, 2004, 12:20:50 AM »
Got a multi meter/test light? wiring diagram?
Mike
GOIN' STROKIN' FOR THE SUMMER[/size][/font]
« Reply #6 on: August 04, 2004, 12:11:14 AM »
BAD FUSE - one of the 16amp fuses had a hairline break - always something stupidly simple that makes you pull your hair out!
Anyways, all fixed :)
Offline Black-Back
« Reply #7 on: August 04, 2004, 11:48:49 AM »
hehehe........ the smallest things are always overlooked........... :wacko:
 Mike
« Reply #8 on: August 04, 2004, 02:50:45 PM »
now to figure out my charging problem - or should I say my no charge problem....
« Reply #9 on: August 04, 2004, 02:59:20 PM »
got a belt on that alternator?
« Reply #10 on: August 04, 2004, 03:16:49 PM »
why, belts slow you down - just ask Brian
Offline Black-Back
« Reply #11 on: August 04, 2004, 03:35:57 PM »
Whoa, Whoa, now keep that in the lounge :lol:
.....you got the battery hooked up? all ground straps? internal or external regulator? all fuses are good?how 'bout a bently or volkswagen for dummies manual? hehehe
Mike
« Reply #12 on: August 04, 2004, 03:50:00 PM »
pretty sure it's my dash light that is giving me the trouble - gonna put in a different one tonight.
