Technical
Electronics & Car Audio Forum
New Fuse Box - No Signals/brake Lights
Topic: New Fuse Box - No Signals/brake Lights (Read 11246 times)
James Buchan
August 02, 2004, 05:07:09 PM »
Ok, I've installed a new
aftermarket
fuse box in my 66. Everything is working except for my turn signals and brake lights. I have hazards, driving lights, headlights and all dash lights.
One noticable difference is that the after market places fuses (the 2 end red fuses) at the drivers side of the panel instead of one on either end. I had to extend a couple of wires to accomadate this. Anyone smart out there that can help me out
Chris
Car.
August 02, 2004, 05:19:33 PM »
Any loose wires on the switches, check your turn signal relay as well. Should be pretty obvious problem, if all you did was swap the fuse box, unless of course your headlights are now your turn signals and vice versa
James Buchan
August 02, 2004, 05:27:33 PM »
I've checked all the connections, I would think if the relay was shot then the hazards wouldn't work.
Like I said everything else works except the brake lights and turn signals.
Chris
Car.
August 02, 2004, 06:00:05 PM »
check your grounds, your brake lights and turn signals are the probably the same, if your stuck I could come by and take a look, are the fuses good? what type of fuse? glass?
Last Edit: August 02, 2004, 06:01:13 PM by 1976BUS
Mowser
"You know, Hobbes, some days even my lucky rocketship underpants don't help. " Calvin
August 02, 2004, 11:42:01 PM »
If memory serves..... VW has an odd way of using signal lights. Check all the wires again that come off of the collumn. Me thinks you inadvertantly hooked up one wrong. I could tell right away if I were there..... sorry bud. The last wiring nightmare I worked on was SlammedBus's Notchback. I imagine they are about the same though..... When in doubt find a copy of the wiring diagram for your car that has colour coding on it. If you have hazards but no signals then it's a signal problem from the collumn. The hazards are direct to the relay but the column goes through the fuse box. Again....... IF MEMORY SERVES!!!
Mo
Black-Back
August 03, 2004, 12:20:50 AM »
Got a multi meter/test light? wiring diagram?
Mike
GOIN' STROKIN' FOR THE SUMMER
[/size][/font]
James Buchan
August 04, 2004, 12:11:14 AM »
BAD FUSE - one of the 16amp fuses had a hairline break - always something stupidly simple that makes you pull your hair out!
Anyways, all fixed
Black-Back
Reply #7 on:
August 04, 2004, 11:48:49 AM »
hehehe........ the smallest things are always overlooked........... :wacko:
Mike
[/size][/font]
James Buchan
Reply #8 on:
August 04, 2004, 02:50:45 PM »
now to figure out my charging problem - or should I say my no charge problem....
Chris
Car.
Reply #9 on:
August 04, 2004, 02:59:20 PM »
got a belt on that alternator?
James Buchan
Reply #10 on:
August 04, 2004, 03:16:49 PM »
why, belts slow you down - just ask Brian
Black-Back
Reply #11 on:
August 04, 2004, 03:35:57 PM »
Whoa, Whoa, now keep that in the lounge :lol:
.....you got the battery hooked up? all ground straps? internal or external regulator? all fuses are good?how 'bout a bently or volkswagen for dummies manual? hehehe
Mike
[/size][/font]
James Buchan
Reply #12 on:
August 04, 2004, 03:50:00 PM »
pretty sure it's my dash light that is giving me the trouble - gonna put in a different one tonight.
Technical
