Engine Tech Forum
Oil Drain Plug
Topic: Oil Drain Plug (Read 4724 times)
Russ
Oil Drain Plug
July 20, 2004, 10:28:14 AM »
how tight does the oil drain plug get tightened at? Silas??
so rry i keep asking but i have a bently manual and i can't find a torque sheet
thanks russ
James Buchan
Oil Drain Plug
July 20, 2004, 10:50:08 AM »
Dload and print this Russ -
http://failsure.net/oacdp/wog72.html
And this too -http://failsure.net/oacdp/wog69.html
Maybe this too -
http://www.1800vw.bizhosting.com/0.case.cyl.htm
Russ
Oil Drain Plug
July 20, 2004, 12:04:30 PM »
excellent
thanks James
russ
Oil Drain Plug
July 20, 2004, 02:11:10 PM »
i didnt read thru all the downloadables that james gave you, so if you still need to know i'm pretty sure its 25 ft/lbs
Last Edit: July 20, 2004, 02:11:28 PM by silas
James Buchan
Oil Drain Plug
July 20, 2004, 02:13:19 PM »
In the first two links you'll find the \"Without Guesswork\" books - lots of good stuff in them.
Engine Tech Forum
Oil Drain Plug
