Author Topic: Oil Drain Plug  (Read 4721 times)
Oil Drain Plug
« on: July 20, 2004, 10:28:14 AM »
how tight does the oil drain plug get tightened at? Silas??  :)
so rry i keep asking but i have  a bently manual and i can't find a torque sheet
thanks russ
Oil Drain Plug
« Reply #1 on: July 20, 2004, 10:50:08 AM »
Dload and print this Russ - http://failsure.net/oacdp/wog72.html
And this too -http://failsure.net/oacdp/wog69.html
Maybe this too -  http://www.1800vw.bizhosting.com/0.case.cyl.htm
Oil Drain Plug
« Reply #2 on: July 20, 2004, 12:04:30 PM »
excellent
thanks James
russ
Oil Drain Plug
« Reply #3 on: July 20, 2004, 02:11:10 PM »
i didnt read thru all the downloadables that james gave you, so if you still need to know i'm pretty sure its 25 ft/lbs
« Last Edit: July 20, 2004, 02:11:28 PM by silas »
Oil Drain Plug
« Reply #4 on: July 20, 2004, 02:13:19 PM »
In the first two links you'll find the \"Without Guesswork\" books - lots of good stuff in them.
