Author Topic: What are my options for brakes?  (Read 3035 times)
Offline Richard Kuczko
« on: June 18, 2014, 08:07:20 AM »
I've heard that it's impossible to put discs on my bus.  And would like to get better stopping power.  Is it true that there is no way to put them on a 4" narrowed adjustable beam. I was thinking rears but not sure.  Anyone have a idea?
Re: What are my options for brakes?
« Reply #1 on: June 18, 2014, 08:23:42 AM »
what year bus Richard?
« Reply #2 on: June 18, 2014, 08:25:54 AM »
69.  I have 14" tires on too
Offline rekka
    • Radwerx Creative Inc
« Reply #3 on: June 18, 2014, 08:28:07 AM »
I recently parted out a 69 double cab that had been converted to late bay discs on the front and later drums on the rear so It can be done with just VW parts, but I'm not sure what the exact combination is. Also you have lots of options with dropped spindle conversions as your beam is already narrowed so width won't be an issue. Geoff may be able to hook you up, if not Wagenswest made me 911/split bus hybrid dropped spindles that work great.
« Reply #4 on: June 18, 2014, 09:28:11 AM »
There are many options out there. If your wanting to keep your drum drop spindles then use one of Lanners adapter kits to late bay or porsche. Only issue is all disc kits have a small bolt circle so you will need to run a adapter that will move the wheel out 1/2- 3/4 so check for tire to the outer support lip at the top of your wheel well.
The issue you will have is the 14" wheels as some brakes only fit 15 and up wheels.
If you run the late bus brakes all should be good.
I can build you a set of dropped disc spindles if need be.
« Reply #5 on: June 18, 2014, 10:57:26 AM »
How much to set me up?
Offline WESTY69
« Reply #6 on: June 19, 2014, 07:10:54 AM »
You never mentioned you had a 69 DC that was getting parted out , anything left of it ?
We are having the same talk about drum to disc , here with friends , Geoff has the goodies and knowledge to do it and I still wonder how because I don't want to loose my wide five look but do have interest in better stopping if it is an easy conversion ?
Offline rekka
« Reply #7 on: June 19, 2014, 08:00:38 AM »
Sorry Jerry all gone now, it was listed in here a while back, a few parts went to board members, Richard had the back bumper (not a DC one). I even shipped the roof and the load bed to the UK!! I'm never cutting one of those off again, it was a bitch.
« Reply #8 on: June 19, 2014, 08:34:33 AM »
Time for a sticky in the Bay section Geoff, lots of interest in this sort of thing.... and would save the email chains to answer the same questions for Airspeed peeps?
« Reply #9 on: June 19, 2014, 10:15:22 AM »
Still have the bumper if anyone needs it.  It worked great till I found a nice one lol.   Thanks Geoff.  I'm on the disc thing
Offline WESTY69
« Reply #10 on: June 19, 2014, 10:21:51 AM »
It's all good and I agree with Brian , a sticky for this topic would be awesome !!
Offline iceneweb
« Reply #11 on: June 19, 2014, 11:40:38 AM »
WagensWest sell a kit that will fit 14" wheels. BabyStang:
wide five four piston vw bus disk brakes that fit under 14 inch wheels : http://www.wagenswest.com/partstore/index.php/disk-brakes/babystang-63-70-bus-front-disk-brakes.html
1971 Westfalia Campmobile
« Reply #12 on: June 19, 2014, 02:50:29 PM »
Really. That would be cool.  Now can Geoff still make drop spindals for that
« Reply #13 on: June 19, 2014, 04:17:22 PM »
Richard as I mentioned in my pms you can run 14" wheels with the drop spindles I build if your using the bus disc brakes
« Reply #14 on: June 19, 2014, 04:21:57 PM »
Yeah sorry about that.  Can you bring them to kelowna if your coming down
« Reply #15 on: June 19, 2014, 04:23:21 PM »
Concepts have them.  I will pick them up there
« Reply #16 on: June 19, 2014, 05:13:59 PM »
Check to make sure they are in stock, spoke to Curtis a few weeks ago and they found that WW was taking some time getting them out.
Offline iceneweb
« Reply #17 on: June 19, 2014, 05:25:40 PM »
I'm interested in the other options you're discussing. What brake kits do Concepts sell? Where are they based?
« Reply #18 on: June 19, 2014, 05:36:16 PM »
They are in Calgary.  Concept1.ca
