Author Topic: Cloth Braid Hose  (Read 3046 times)
Offline super90kyote
Cloth Braid Hose
« on: May 31, 2014, 11:39:14 AM »
Does anyone remember that cloth braid, rubber lined hose. You could buy it from Bow Wow many yaers ago.
It came in small sizes, fuel lines, vacume etc.
Who carries it now???
Re: Cloth Braid Hose
« Reply #1 on: May 31, 2014, 12:27:06 PM »
Try AVR, if they don't I know Germansupply.com does.
Keep in mind the fuel line is not compatible with ethanol so you'll have to run Chevron 94 or switch to J30R9 fuel injection hose from your FLAPS.
« Reply #2 on: May 31, 2014, 05:45:13 PM »
I've been running 10% ethanol through AVR's fabric fuel lines for years, check em often and no problems.
Offline purple turd
« Reply #3 on: June 01, 2014, 09:14:27 PM »
Altrom. In van which is also available from napa
« Reply #4 on: June 01, 2014, 09:39:45 PM »
...................... check em often and no problems......
Exactly, it's hit and miss, some batches stand up fine for years, others turn into soaker hose in just a few weeks, if you run it inpect it carefully every time you check the oil. Look/smell for wet areas and wiggle each line near the fittings when it's under pressure, some can look good but squirt a pin sized stream out when you wiggle it.
Gasoline fed fires suck.
« Reply #5 on: June 02, 2014, 05:18:11 PM »
Hey, thanks for the info.
I'm told that NW Fuel Injection, in Port Kells carries all sizes.
I haven't been there yet.
Cheers
« Reply #6 on: June 02, 2014, 07:35:32 PM »
x3
...and without getting too far off topic...lift your lid/check your oil every time you get gas. and if you don't get gas often, lift your lid/check & inspect before every drive! it's one of the cheapest and easiest forms of preventative maintenance you can do!  :)
Offline Parts
« Reply #7 on: June 03, 2014, 08:49:08 AM »
Nope. Theirs is made by Meyle Germany (Part of the brand name, has nothing to do with the actual country).
China's finest.
Get the stuff made by Continental. Available through Worldpac, which any FLAPS should have access to.
Offline bagged oval
« Reply #8 on: June 03, 2014, 10:29:00 PM »
got mine from lordco in mission >
