Author Topic: Turn signal/headlamp flasher switch question  (Read 9238 times)
Offline rekka
    • Radwerx Creative Inc
« on: June 23, 2013, 10:43:52 AM »
Hi, this is a switch from a 69 bay. Can anyone tell me where this broken wire (Brown/white) is supposed to be hooked to. I cant see any signs of damage or broken solder joint at all. Thanks.
Re: Turn signal/headlamp flasher switch question
« Reply #1 on: June 23, 2013, 12:39:46 PM »
Brown/white is high beam change so it'll attach to one of the contacts that close when you pull back on the lever.
Offline rekka
« Reply #2 on: June 24, 2013, 02:22:52 PM »
Thanks a lot Busdaddy. I can now solder it on where it will work but cannot see exactly where it was supposed to be.
« Reply #3 on: June 24, 2013, 03:44:50 PM »
Offline Richard Kuczko
« Reply #4 on: June 24, 2013, 04:36:49 PM »
Wow awsome help.  Now I even see where it goes
Offline rekka
« Reply #5 on: June 24, 2013, 06:08:10 PM »
So do I. Thanks you so much BUSDADDY. This is actually a switch I've sold to someone else on here (for way too cheap :-)
Now I'll be able to assure him it works 100% This is a team effort.
