Technical
Electronics & Car Audio Forum
Turn signal/headlamp flasher switch question
Topic: Turn signal/headlamp flasher switch question (Read 9227 times)
rekka
AirSpeed Forum Member
June 23, 2013, 10:43:52 AM »
Hi, this is a switch from a 69 bay. Can anyone tell me where this broken wire (Brown/white) is supposed to be hooked to. I cant see any signs of damage or broken solder joint at all. Thanks.
Radwerx. Architectural features in wood, metal and concrete
www.radwerx.ca
BUSDADDY
Re: Turn signal/headlamp flasher switch question
June 23, 2013, 12:39:46 PM »
Brown/white is high beam change so it'll attach to one of the contacts that close when you pull back on the lever.
rekka
June 24, 2013, 02:22:52 PM »
Thanks a lot Busdaddy. I can now solder it on where it will work but cannot see exactly where it was supposed to be.
www.radwerx.ca
BUSDADDY
June 24, 2013, 03:44:50 PM »
Richard Kuczko
June 24, 2013, 04:36:49 PM »
Wow awsome help. Now I even see where it goes
70 tintop kombi. "Never 4 Sale!!!!"
rekka
June 24, 2013, 06:08:10 PM »
Quote from: Richard Kuczko on June 24, 2013, 04:36:49 PM
So do I. Thanks you so much BUSDADDY. This is actually a switch I've sold to someone else on here (for way too cheap :-)
Now I'll be able to assure him it works 100% This is a team effort.
www.radwerx.ca
Technical
