Author Topic: Heater/cooling lever removal  (Read 3876 times)
Offline 1969deluxebus
« on: September 12, 2012, 11:45:13 PM »
I am wanting to change my speedo needle  and to do that I need to take the gauge pod out. Anyone have a trick or advice for taking out those clips that hold the heater levers in.
Re: Heater/cooling lever removal
« Reply #1 on: September 13, 2012, 07:07:39 AM »
Push a 7mm or 8mm socket onto the pointy end and they pop right out, disconnect the battery first as the metal antirattle spring falls onto the hazard switch when you pull the lever out.
« Reply #2 on: September 14, 2012, 02:25:37 PM »
