Specialty Forums
Bay- curios?
Heater/cooling lever removal
Topic: Heater/cooling lever removal (Read 5956 times)
1969deluxebus
Cruising in a Bay is the only way.
September 12, 2012, 11:45:13 PM »
I am wanting to change my speedo needle and to do that I need to take the gauge pod out. Anyone have a trick or advice for taking out those clips that hold the heater levers in.
BUSDADDY
Re: Heater/cooling lever removal
September 13, 2012, 07:07:39 AM »
Push a 7mm or 8mm socket onto the pointy end and they pop right out, disconnect the battery first as the metal antirattle spring falls onto the hazard switch when you pull the lever out.
1969deluxebus
September 14, 2012, 02:25:37 PM »
Specialty Forums
Bay- curios?
