Author Topic: Axel tube cover instalation  (Read 7404 times)
Offline mcbeese
« on: September 05, 2011, 12:50:31 PM »
I'm just putting my axel tubes on my 62 type 1 trany. One side I put on 3 gaskets on the cover and it is snug the other 2 gaskets  and it is tight in the up and down position and loose in the middle. What is the procedure  for setting theses up??????
Re: Axel tube cover instalation
« Reply #1 on: September 05, 2011, 05:20:03 PM »
You need to make the tube articulate through it's entire motion freely.  Add gaskets until it does.
But..... you don't want excessive play.
Offline mcbeese
« Reply #2 on: September 07, 2011, 08:36:47 AM »
Thanks, Right now it seems to stick on the extreem top and bottom...
« Reply #3 on: September 07, 2011, 06:29:51 PM »
I don't know about the gasket kits available today, but originally VW sold gaskets in 2 thicknesses so you can fine tune the play.  If you think yours is binding at a position that will never occur at your car's ride height, you may be ok as is.
