Technical
Transmission Forum
Axel tube cover instalation
Topic: Axel tube cover instalation (Read 7406 times)
mcbeese
September 05, 2011, 12:50:31 PM »
I'm just putting my axel tubes on my 62 type 1 trany. One side I put on 3 gaskets on the cover and it is snug the other 2 gaskets and it is tight in the up and down position and loose in the middle. What is the procedure for setting theses up?
Bruce
Re: Axel tube cover instalation
September 05, 2011, 05:20:03 PM »
You need to make the tube articulate through it's entire motion freely. Add gaskets until it does.
But..... you don't want excessive play.
mcbeese
September 07, 2011, 08:36:47 AM »
Thanks, Right now it seems to stick on the extreem top and bottom...
Bruce
September 07, 2011, 06:29:51 PM »
I don't know about the gasket kits available today, but originally VW sold gaskets in 2 thicknesses so you can fine tune the play. If you think yours is binding at a position that will never occur at your car's ride height, you may be ok as is.
Technical
Transmission Forum
