Author Topic: Has anyone ever used this engine kit  (Read 5179 times)
Offline blarneyman
« on: July 08, 2011, 04:46:06 PM »
Thinking about building a motor for my bug. I'm new at engines so be gentle with me (but honest) You_Rock_Emoticon
http://www2.cip1.com/ProductDetails.asp?ProductCode=C15%2D2027%2D1
My reasons for thinking this way. I like the stability of a stock 1600 and this is as close (proportionately) while going bigger.
« Last Edit: July 08, 2011, 04:48:46 PM by blarneyman »
www.mbvv.org
My \"new\" 1970 Ghia
Re: Has anyone ever used this engine kit
« Reply #1 on: July 09, 2011, 10:48:52 AM »
That's quite a big step from a stock engine!
There's one item in that kit that is fatal, IMO.  That is the Scat lifters.  Do not use them.  If you buy the kit, sell those lifters.
I would not use the pushrod tubes they supply.  Use stock type tubes.
Offline buggal
  • April McNicol
  • 1972 STD Beetle project
« Reply #2 on: July 09, 2011, 12:08:58 PM »
I agree, and the cylinders are not the best either. They are thin walled and have more possibility of deforming.
There's a good article on building your own engine here:
 http://www.aircooled.net/gnrlsite/resource/articles/t1hpeng.htm
Building an engine is fun. Go slow and keep it CLEAN.
Offline blarneyman
« Reply #3 on: July 09, 2011, 12:43:25 PM »
Any suggestions on a solid long life motor with a fair amount of pop to it? Wasn't aware of the thin walled jugs. I was reading about some of these motors getting hot easily. Don't want to go that route if I can avoid it. ???
www.mbvv.org
« Reply #4 on: July 09, 2011, 11:18:51 PM »
... the cylinders are not the best either. They are thin walled and have more possibility of deforming.
I think you're mistaking the cylinders in that kit for 92s.  The 90.5s are not "thin walled".
Offline buggal
  • April McNicol
« Reply #5 on: July 10, 2011, 06:16:37 AM »
You're right. That's why I included that link. It is a very good article.   :sorry:
Offline blue bus
« Reply #6 on: July 11, 2011, 06:39:29 AM »
If you have the dough you might want to try one of Jake Raby's kits
Offline blarneyman
« Reply #7 on: July 11, 2011, 03:18:30 PM »
That's out of the question. At this point I'm looking at building one because I can't afford to buy a turn-key.
www.mbvv.org
Offline GMB
« Reply #8 on: July 14, 2011, 11:09:36 AM »
Hey Blarney check out my "Crate Engines" at CIP. I have designed these for reliability and longevity. just pick your displacement 1600, 1914 or 2276. completely brand new nothing used or rebuilt. built by Scat exclusivly for CIP.
@$3499 I think the 1914 long block, already assembled, would be right up your alley!
http://www2.cip1.com/SearchResults.asp?Cat=1272
Gary
« Last Edit: July 14, 2011, 11:16:03 AM by GMB »
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
« Reply #9 on: August 09, 2011, 07:20:43 PM »
can you tell me what kinda lifters you use? i have heard not so great things about scat lifters...
Offline Bubba
« Reply #10 on: August 10, 2011, 05:18:01 PM »
Jake will not be taking kit orders again until November 2011, with delivery Feb. 2012.
He will have 6 kits available then, and those will be the year's allotment.
His turnkey engine cost is around 2-3 times the kit cost, and you can probably get it delivered within a year.
« Last Edit: August 11, 2011, 01:48:41 PM by Bubba »
64 Beetle
86 Nissan Multi
81 Rabbit
90 Malibu Euro F3
94 H-D FXDWG
Offline dwvw
« Reply #11 on: August 10, 2011, 09:35:09 PM »
Has anyone used the CB Performance kits?
http://www.cbperformance.com/catalog.asp?ProductID=1781
Offline GMB
« Reply #12 on: August 11, 2011, 08:27:38 AM »
Hey Kirin These "Crate Engines" use Scat lifters. I have been selling "my formula" Scat engines (1914cc and 2275cc) for years now and have never had a problem with lifters.
We have just focused this formula into a marketable product and instead of offering every combo in the world (very confusing for Customers) it's been my opinion for a while now that there are really only 2 engine sizes worth building.
1914cc just because the barrel thickness is almost as thick as the 90.5s and it is the biggest engine you can build on a 69 crank. This engine with 1.1:1 rockers works well with a re-jetted 34mm pict carb and a 4 into 1 header.
2275cc this is just a stroked out 1914 using an 82 stroke crank. If put together for street daily driver use the 2275, using the "B" style stroker pistons, is the same width as a 1600 wich with a set of single HD valve springs allows the use of stock aluminum pushrods as well!
All Our crate engines have the same cam shaft in them and are set up for daily driving street or offroad use.
Gary.
Warrior sand rail:
2276cc 82x94
Stock lifters
Offline Darren
« Reply #13 on: August 16, 2011, 03:58:36 PM »
2-3 Times the cost is that accurate?  so if the 1914 kit is roughly 3K then you are looking at 6-9K for a turn key?
That is just crazy..... I should raise my prices I guess....... :D
Offline Bubba
« Reply #14 on: August 16, 2011, 04:34:03 PM »
His kits are between 5 and 6k without prep, but balancing included, provided you have useable cores.  From what he says on his site, turnkey engines are 12k and up.  He currently has an 8 month backlog on turnkey engines.
64 Beetle
86 Nissan Multi
81 Rabbit
90 Malibu Euro F3
94 H-D FXDWG
« Reply #15 on: August 16, 2011, 04:34:22 PM »
This is Jake Raby he's talking about, his t4 engines turn key are $$$$ due to all the custom exhaust and add ons he dose. I don't agree with his prices but I do know he charges$$$$
« Last Edit: August 16, 2011, 04:37:12 PM by Geoff »
Offline Darren
« Reply #16 on: August 17, 2011, 09:17:45 AM »
one should shop around some more....... those prices are crazy..............
I could do a full custom 2387 Dual throttle bodies, EFI with Stainless exhaust, complete turn key all new ( no cores needed ) installed and tuned for well under 10K....
