Author Topic: Oil filters.  (Read 7885 times)
Oil filters.
« on: September 24, 2010, 08:52:04 AM »
Has anyone ever had a oil filter come loose on them? What do you guys/girls recommend?
Thanks,Brian.
Re: Oil filters.
« Reply #1 on: September 24, 2010, 09:29:57 AM »
put it on properly
Re: Oil filters.
« Reply #2 on: September 24, 2010, 09:56:42 AM »
Lol. I had a feeling someone would say that. I'm sure it was on as tight as I could get it. Glad it happened at home and not on the track.
Re: Oil filters.
« Reply #3 on: September 24, 2010, 10:58:49 AM »
dont overtighten your oilfilter!
Offline mizovalgrl
Re: Oil filters.
« Reply #4 on: September 24, 2010, 11:03:28 AM »
Is that because when it heat's up it will then expand and pop off. I was told to turn until snug and then counter turn a little. Is that correct?
Re: Oil filters.
« Reply #5 on: September 24, 2010, 12:07:57 PM »
Re: Oil filters.
« Reply #6 on: September 24, 2010, 12:16:46 PM »
Helpful as usual, Chris.  lol_hitting
Re: Oil filters.
« Reply #7 on: September 24, 2010, 12:39:21 PM »
I try
Re: Oil filters.
« Reply #8 on: September 24, 2010, 04:10:05 PM »
What's snug?
Best is to follow the directions on the filter or it's box.  Usually it says to tighten it 3/4 - 1 turn after the seal contacts the surface.
Re: Oil filters.
« Reply #9 on: September 24, 2010, 05:29:53 PM »
Good idea to check the old filter when it comes off to make sure the gasket came off with it too, if it sticks to the engine you'll have all sorts of issues including coming loose.
Offline mizovalgrl
Re: Oil filters.
« Reply #10 on: September 24, 2010, 05:31:59 PM »
Thank's Bruce you're correct everybody has their definition of what "snug" is. I usually turn it until it has contact with the surface area, but not over turn to cause it to strip. Perhap's I should start  reading the direction's.... lol_hitting Thank's for your help.
Re: Oil filters.
« Reply #11 on: September 24, 2010, 07:54:58 PM »
about the same pressure i put around my victim's necks when i choke them out,... firm grip then a kwick twist.
