Author Topic: Rear Axle Nut Removal Tool?  (Read 2735 times)
Offline RickyG
« on: July 03, 2010, 04:59:51 PM »
Hi,
Anyone have this tool lying around that we can borrow?
We've used a cheater bar and had 2 guys standing on it (probably put out about 500ft.lb of torque) but still unable to get it off.
Please help!
Re: Rear Axle Nut Removal Tool?
« Reply #1 on: July 03, 2010, 06:41:17 PM »
Some times it's not the torque it's the shock. Have you got one of the slug wrench type wrenches? Use a 5 or so lb sledge on the slug wrench a lot of times this breaks them free. Use to do that all the time in the refinerys to break man hole bolts loose, 1 inch drive impacts wouldn't break them loose but a sledge hammer would!
Gary
« Reply #2 on: July 03, 2010, 06:43:05 PM »
Where bouts are you. I have something that should work if you can't find a Torqumeister tool.
Offline beetlemandan
« Reply #3 on: July 03, 2010, 07:41:22 PM »
i made my own slugwrench with a piece of 1/2" a.r. plate and a torch. it works awesome!!! and when in doubt, a cold chisel and hammer will also take that nut off, but will ruin it altogether. or you can heat the nut with a torch, but you risk heating the bearings and destroying the axle seals.
but over all, a good impact, and if that fails, a slug wrench. the other two options are a last resort thing
the customer is always wrong
Offline RickyG
« Reply #4 on: July 06, 2010, 02:43:23 PM »
I'm in south Richmond in Steveston.
Offline RickyG
« Reply #5 on: July 06, 2010, 02:45:29 PM »
Gary
We tried hammering the cheater bar on a wrench. jumping on the cheater bar etc, and no luck.
« Reply #6 on: July 06, 2010, 03:31:22 PM »
You need one of these:
http://avrparts.com/shop/product_info.php?cPath=92&products_id=388
And a 5lb sledge. Hammering on your cheater bar just flexes the bar. Otherwise, like the guys said...put heat to it.
« Reply #7 on: July 06, 2010, 06:10:56 PM »
Are you turning it the right way?
« Reply #8 on: July 06, 2010, 06:31:45 PM »
I was offering this
pm your number if you want to give it a try. We're in Langley.
It looks terrible but it works
Offline RickyG
« Reply #9 on: July 07, 2010, 04:07:25 PM »
Unless the thread is reverse threading, we are definitely turning the "counter clock wise" way.
Offline RickyG
« Reply #10 on: July 07, 2010, 04:08:28 PM »
I was offering this
I think it looks pretty good. nice n beefy.
you have pm.
Offline AlanU
« Reply #11 on: July 08, 2010, 01:00:45 AM »
I've simply used a 3/4 breaker bar with socket. I take the handle off of the floor jack for leverage.
Offline iceneweb
« Reply #12 on: July 08, 2010, 01:15:39 PM »
I have a cheapo 3/4" socket set from Princess Auto for the big stuff. There is no 46mm, but the 45mm one can be persuaded on for a nice tight, no wobble or slip fit. I then slip a piece of pipe over the T Bar.
1971 Westfalia Campmobile
« Reply #13 on: July 08, 2010, 05:05:52 PM »
A little heat will work wonders as well. Get it red hot and douse it in WD-40. Works every time. Well most of the time.  ;D
Offline Bubba
« Reply #14 on: July 10, 2010, 07:41:28 AM »
Getting the nut red hot is ok if you intend to replace it.
Depending on how it cools, you may be altering the properties of the material, and not in a good way.
You should not need anything over 400F to break torque.  Red hot is twice that temperature.
64 Beetle
86 Nissan Multi
81 Rabbit
90 Malibu Euro F3
94 H-D FXDWG
« Reply #15 on: July 10, 2010, 11:20:27 AM »
Yeah. What he said.  iagree
Offline Schvengy
« Reply #16 on: July 11, 2010, 08:34:12 PM »
I just took mine off with a 4ft breaker bar and a 8 ft pipe from my neighbours house ...no problem !! ;D
Offline KOOL-AID MAN
« Reply #17 on: July 12, 2010, 10:08:03 PM »
Maybe you know someone with air tools? get an impact drill on there. My dad has an electric impact that always got mine off when i couldn't do it with the breaker bar.
Tom
