Author Topic: Trouble getting engine running  (Read 6430 times)
Offline EricJr
« on: June 04, 2010, 11:17:39 PM »
I have a 1915cc that i had running for about a month. I drove it out to White Rock one afternoon and on the way it backfired a few times and died. It would turn over but not start. Found there was no spark. I have replaced the coil with a new blue coil, new compufire electronic points and a new alternator with built in regulator and I now have spark but it just wont fire up. I have static timed it to TDC on number one but nothing seams to work. I pulled the distibutor and the drive gear doesn't line up the way it is supposed to, prob 30 deg off but i adjusted the dist to allow for this. I was getting some backfire through the carbs but now nothing. Anybody have any ideas?
Re: Trouble getting engine running
« Reply #1 on: June 04, 2010, 11:33:09 PM »
what kind of distributor?
Offline EricJr
« Reply #2 on: June 05, 2010, 05:20:39 PM »
I didn't build the engine but as far as i can tell its a stock distributor
« Reply #3 on: June 05, 2010, 07:28:55 PM »
does it have vacumn lines?
Offline JohnB
« Reply #4 on: June 05, 2010, 10:29:27 PM »
Out of gas?
Offline EricJr
« Reply #5 on: June 06, 2010, 10:51:50 PM »
No vacuum and yes, its got gas. I detached the fuel line and cranked it over because it seamed to be flooded. Now I get alot of back fire through the carb so I figured the timing was out. Once again I static timed it but still won't fire. If anybody lives close to coquitlam and has an hour or so to come by and have a look I would appreciate it. Its pissing me off, all these sunny days and I can't drive it!
« Reply #6 on: June 07, 2010, 07:01:01 AM »
Sounds like your timing for a stock distributor and are not using a stock one. You need to get the numbers off the distributor and post them then more info can be provided.
Offline EricJr
« Reply #7 on: June 07, 2010, 04:12:34 PM »
K will do thanks Chris.
Offline EricJr
« Reply #8 on: June 22, 2010, 08:57:44 PM »
The distributor doesn't have any markings or numbers. I worked on it on Saturday and its cranking over but backfiring like crazy and still wont start. I cranked it over while turning the distributor to check if it was out but still couldn't make any progress.
« Reply #9 on: June 22, 2010, 09:29:03 PM »
Just where are you at? sounds like you need to stock the fridge and have someone come visit.
Offline EricJr
« Reply #10 on: June 23, 2010, 09:45:51 PM »
I need help! Is there anyone that can come by for an hour or so and have a look? I didn't want to go through the hassle of having it towed somewhere. Does anybody know of a good vw shop in tri-cities or have a suggestion on where I should take it?
« Last Edit: July 14, 2010, 10:45:18 PM by EricJr »
