Engine Tech Forum
help....78 westy FI
Topic: help....78 westy FI (Read 3007 times)
bct
help....78 westy FI
May 27, 2010, 06:05:04 PM »
changed the fuel injection lines today and now it won't idle.....should i be bleeding the system ?....runs great at higher rpm and will not idle at lower .....seems to pop then the engine revs..... i have to "feather" the gas pedal to keep it running at just above idle as soon as ilet off the feul it dies....thanks for any and all help....
BUSDADDY
Like potato chips, you can't have just one
Re: help....78 westy FI
May 27, 2010, 07:01:28 PM »
Find the vacuum hose you knocked off while changing the lines, then reconnect the temp sensor 2, it's likely disconnected too.
bct
May 28, 2010, 05:30:27 AM »
yes that is my next step today....i can hear a serious hiss.....can't find it tho....thanks for the confirmation
bct
May 28, 2010, 08:11:49 AM »
hahaha....duhh.....thanks
stu817
June 10, 2010, 12:37:55 AM »
if you are looking for a vacuum leak try spraying around the area you think it is with carb cleaner and the engine will slow down when you find it
Engine Tech Forum
help....78 westy FI
