Author Topic: help....78 westy FI  (Read 4258 times)
Offline bct
help....78 westy FI
« on: May 27, 2010, 06:05:04 PM »
changed the fuel injection lines today and now it won't idle.....should i be bleeding the system ?....runs great at higher rpm  and will not idle at lower .....seems to pop then the engine revs..... i have to "feather" the gas pedal to keep it running at just above idle as soon as ilet off the feul it dies....thanks for any and all help....
Re: help....78 westy FI
« Reply #1 on: May 27, 2010, 07:01:28 PM »
Find the vacuum hose you knocked off while changing the lines, then reconnect the temp sensor 2, it's likely disconnected too.
Offline bct
« Reply #2 on: May 28, 2010, 05:30:27 AM »
yes that is my next step today....i can hear a serious hiss.....can't find it tho....thanks for the confirmation
Offline bct
« Reply #3 on: May 28, 2010, 08:11:49 AM »
hahaha....duhh.....thanks
Offline stu817
« Reply #4 on: June 10, 2010, 12:37:55 AM »
if you are looking for a vacuum leak try spraying around the area you think it is with carb cleaner and the engine will slow down when you find it
