Author Topic: Clutch tube mount  (Read 4894 times)
Offline Thomas
Clutch tube mount
« on: May 27, 2010, 10:52:51 AM »
I picked up a factory rebuild swing axle tranny and the only differance I noticed was the clutch tube holder is not part of side plate. Should I use the side plate from my trans or try and find a bolt on bracket used on newer swing axles. Also where does the backup switch mount on this tranny. Thanks Thomas
Re: Clutch tube mount
« Reply #1 on: May 27, 2010, 08:48:00 PM »
You should get the bracket from a later gearbox.  I'm sure CIP sells it too.
You can't swap the side covers, that would alter the bearing preload, and the ring gear backlash.
Offline Thomas
« Reply #2 on: May 31, 2010, 10:55:24 AM »
Thanks for the info Bruce, the guy I got the tranny from dropped off a bracket for me. Cheers Thomas
