Author Topic: How Low Is Too Low For The Aircare Dyno?  (Read 3353 times)
« on: April 20, 2004, 08:27:36 PM »
Hey guys.
I only want to take a idle test on Seabert.
And a easy way to get out of it is have her so low she can't clear the dyno..
So would slammed 4 inches with a lowered sway bar sticking down do it?
Thanks..
-kirin
« Reply #1 on: April 20, 2004, 08:59:04 PM »
You can do that? (get out of the dyno part that is)
« Reply #2 on: April 20, 2004, 09:11:18 PM »
if your car can't clear the dyno they can't test it
The other option is to get a friend of the opposite sex to take it through and hope for the best..
Time to break out the methyl hydrage I guess.
-Kirin
Offline captCRUNCH
« Reply #3 on: April 20, 2004, 09:25:20 PM »
hey kirin, i used to work at the richmond air care station. its true that if the car is too low then it can't be dyno'd also if the tire's on there are to low of a profile with nice rims then they probably wont test it either cause when the rails press in they would damage the rims. also you could go threw air care in the winter season and put studded tire's on the back (also a no go on the dyno) however you can only run studded tire's on the street in certain months. you could also try to convince them that you are dissabled and need a wheel chair...but with a bug i don't think that would fly. even if you get your cutest lady friend with the biggest knockers and the j-lo ass it wouldn't matter cause its all in the anilizer and not the testers themselves (however i won't deny that the way that a car is drivin on the test effects the results...however there is no way to drive to give a pass everytime). good luck.
« Reply #4 on: April 20, 2004, 09:33:26 PM »
Guess I'm stuck using the good old tried and tested way
« Reply #5 on: April 20, 2004, 09:34:37 PM »
Hey Kirin, you can borrow my rims for the test - they would be an expensive mistake for them to run you thru.
« Reply #6 on: April 20, 2004, 09:39:09 PM »
I don't think your serious James..
If you are P-mail me and I think you just may be running me another favour(#4589)
-kirin
« Reply #7 on: April 20, 2004, 10:15:31 PM »
I'm serious, just let me know when.
Offline thrasherbill
« Reply #8 on: April 20, 2004, 10:50:21 PM »
Kirin, my '68 has only been on the dyno once (stupid bitch dropped the clutch and almost launched the car into the wall ]:( ) They just mark it down as a lowered chassis. I think if it looks like anything (exhaust, suspension, etc) will hit the ground when the car drops into the rollers they won't test it. Although, as I think was stated in another thread, the dyno is the easy test for old VW's. The idle test is harder to tune for, so there isn't usually much advantage to skipping the dyno. Personally, I just don't like those idiots driving my car.
So aparently, this is low enough  :rockon:
ThrasheR
CLICK.
Pinhead Lounge
Offline reefreshd_jive
« Reply #9 on: April 20, 2004, 10:57:51 PM »
my super was a just a little lower than a pepsi can. they made me go over the dyno once, and i hit...ooops. they told me to...but i failed it anyways. and when i came back a week later, they told me to go around. if you are at all interested, the guy at the bug shop charged me 60 bucks, to test it on his machine. the second time i flew threw it. it seemed to work great.
later
james
« Reply #10 on: April 21, 2004, 06:56:51 AM »
Kirin, why dont you put studded snow tires on your car and see what they do with it. They do something different from what I understand. Worth a try.
« Reply #11 on: April 21, 2004, 07:01:33 AM »
only thing is I don't have any studded snow tires.
It sounds like I'll take advantage of Mr. Buchans offer.
With his tires up front my car is going to be raked like crazy and bottoming out on curbs.
Will be an interesting week.
-Kirin
« Reply #12 on: April 21, 2004, 07:06:36 AM »
So now all I'm down to is the idle test. I think I will probably just go to the bugshop and plop down the cash to get it analyzed and tuned for aircare. Can't wait for that craziness to go away(Aircare) And bill my bug is about as low in the front as your 68.  Last measure was like  4 inches from the rear apron to the ground. I had to bring a floor jack in from the side to raise it.
-Kirin
« Reply #13 on: April 21, 2004, 07:14:50 AM »
You could also go to Rudy Feeg and get it checked. My friend Mike works there and he has all the Aircare shit for it. They are right behind Bow Wow. Good luck.
« Reply #14 on: April 21, 2004, 10:11:57 AM »
Or Duane's in Langley, he has a machine too.
Offline Pipes
« Reply #15 on: April 21, 2004, 12:25:05 PM »
Eds great, and only like 40bux!  hit him up!  My bug didn't have to do the dyno either!
Trying for low, show & go
1967 Beetle
« Reply #16 on: April 21, 2004, 06:19:00 PM »
Did he actually get that machine fixed??? I took my bus through there and he tuned it by \"feel\"....failed three more times.
« Reply #17 on: April 21, 2004, 07:23:59 PM »
Yup his machine is running now.
« Reply #18 on: April 21, 2004, 10:13:12 PM »
Duane actually tested my bug last time I attempted aircare..
-Kirin
« Reply #19 on: April 22, 2004, 09:42:19 PM »
kirin, my bros GTI is too low to run on the dyno, so they just did the idle test on it.
Stephan
« Reply #20 on: April 23, 2004, 12:00:48 AM »
You can't do the studded snow tire thing right now.  Studded tires are now illegal, so you aren't exempt from the dyno test.  They will just refuse to test it.
