Author Topic: my engine build  (Read 29875 times)
Offline Kevin K
my engine build
« on: December 04, 2009, 09:54:07 PM »
hey my name is kevin and im 13 years old. im just posting something on for the first time these are some pictures of the engine that Im building with my dad ,(hans k).
fortunately i have cleaned out the case ,glad thats out of the way!!!
although i will have to reclean the case after i hopefully machine it for 94's! ;D
i couldn't find out how to put my pics on so chris posted them for me, their a few posts down
thanks chris
« Last Edit: December 07, 2009, 07:53:57 AM by Kevin K »
1960 bug
Re: my engine build
« Reply #1 on: December 04, 2009, 11:35:13 PM »
welcome Kevin, and you need to use the public gallery links from your facebook to make the pictures work, otherwise you can email them to me and I can post them for you.
Chris@1976bus.com
Re: my engine build
« Reply #2 on: December 05, 2009, 09:20:20 AM »
Welcome Kevin.
I look forward to see the progress on your engine.
« Last Edit: December 05, 2009, 11:20:04 AM by egspot »
Re: my engine build
« Reply #3 on: December 05, 2009, 09:50:16 AM »
Hey Kevin! Nice to have you posting on the ASF. Keep us updated with lots of pics.
Re: my engine build
« Reply #4 on: December 05, 2009, 10:28:45 AM »
Kevin is that going in the buggy?
Gary (neighbor)
Offline Kevin K
Re: my engine build
« Reply #5 on: December 06, 2009, 06:44:36 PM »
no this engine isn't going into the buggy
i don't think my dads buggy is going to get any better then stock :'(
« Last Edit: December 06, 2009, 06:52:24 PM by Kevin K »
1960 bug
Re: my engine build
« Reply #6 on: December 06, 2009, 08:23:49 PM »
Kevins pics!
Re: my engine build
« Reply #7 on: December 06, 2009, 08:35:31 PM »
Thanks Chris.
Keep it up Kevin.
If you change your mind and decide to go a different way   (9o.5s ) send me  a pm.
Offline Kevin K
Re: my engine build
« Reply #8 on: December 07, 2009, 07:45:09 AM »
thanks chris for posting the pictures.
thanks egspot but right now we are just looking for one more 94x69 piston
1960 bug
Offline GMB
Re: my engine build
« Reply #9 on: December 09, 2009, 08:54:05 AM »
Wow Kevin that was quite a mess to clean up it looks great now!. Let me know when you are ready for machinng and I'll give you a hand! E mail me at work as I have found some stuff in storage You may be interested in.
    Gary.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Offline VWinTHEblood
Re: my engine build
« Reply #10 on: December 14, 2009, 02:34:49 PM »
If you are running those stock heads, I have a pair of OE manifold end castings if you can have if you want them.
Offline Kevin K
Re: my engine build
« Reply #11 on: December 15, 2009, 07:42:13 AM »
thanks for the offer but im not going to be needing them because im not runing a stock carb
1960 bug
Offline Jord63
  • Jordan Woodley
Re: my engine build
« Reply #12 on: January 02, 2010, 03:13:33 PM »
Wow Kevin, that looked like a nasty job. Way to dig in and get it done. Looks great.
Re: my engine build
« Reply #13 on: January 02, 2010, 08:38:17 PM »
nice job so far dude ,  PDT_Armataz_01_37
Offline Kevin K
Re: my engine build
« Reply #14 on: May 10, 2010, 04:45:50 PM »
sorry for taking so long to post again...
since last post i have ,got all my case savors in,get my case machined for 94x69 and clean my case ,again
any way, they say that a picture says a thousand words
and since i don't want to wright a thousand words I'm just going to put pics up
1960 bug
Offline Kevin K
Re: my engine build
« Reply #15 on: May 10, 2010, 04:48:23 PM »
 just click on the pics
they will come up full size :)
« Last Edit: May 10, 2010, 09:07:23 PM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #16 on: May 10, 2010, 04:51:01 PM »
« Last Edit: May 10, 2010, 09:07:47 PM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #17 on: May 10, 2010, 04:52:28 PM »
1960 bug
Offline vwguy
Re: my engine build
« Reply #18 on: May 10, 2010, 09:10:16 PM »
Hey Kev, Great job so far, I would recommend some form of treatment for the case, that white powdery stuff will come back to haunt you if you leave it to long.  You can use WD- 40 or   Moovit ,  I always spray the whole case for storage ,just remember to clean all the sealing surfaces well before applying your favorite sealant . Double check the lifter bores for wear and the main oil  relief piston bore for wear. Make sure that the bore for the distributor drive is clean, and the drive can be installed freely.  Good luck on the build, you will do just fine.
  Jimmy D
Offline Kevin K
Re: my engine build
« Reply #19 on: May 10, 2010, 09:24:43 PM »
thanks for the advise Jimmy
my dad is looking over my shoulder making sure that every thing is going to work out in the end
thanks
1960 bug
Re: my engine build
« Reply #20 on: May 11, 2010, 06:39:22 AM »
Good job.  Its great to see you doing this with your dad.  My initial are also Kevin K.
Offline Kevin K
Re: my engine build
« Reply #21 on: May 11, 2010, 03:20:54 PM »
ya, i wouldn't be able to build an engine with out his help and parts
« Last Edit: May 12, 2010, 08:49:42 AM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #22 on: May 13, 2010, 07:52:07 AM »
now the next thing to do to the case is to drill and tap it to make it full flow
oh and also drill and ream my crank shaft to be able to put over sized dowel pins in it
1960 bug
Offline Kevin K
Re: my engine build
« Reply #23 on: May 16, 2010, 09:34:50 AM »
although this has nothing to do with my engine i just thought this was real cool!!
1914cc-240hp
click bellow
http://www.youtube.com/watch?v=d2frvQNmuS8
« Last Edit: May 16, 2010, 09:37:15 AM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #24 on: August 07, 2010, 09:36:09 AM »
me and my dad finished taping my case for full flow and now i just have to drill and ream my crank shaft so i can fit over sized dowl pins in it
then im told that i can start fiting every thing
1960 bug
Re: my engine build
« Reply #25 on: August 07, 2010, 12:39:59 PM »
Nice work Kev, keep us updated and remember your Mom is always right.
Offline Kevin K
Re: my engine build
« Reply #26 on: August 08, 2010, 07:42:33 AM »
 iagree ...oh and my dad is always taller then me
thanks
1960 bug
Re: my engine build
« Reply #27 on: August 08, 2010, 09:59:19 PM »
.. my dad is always taller then me ......
For a little while longer.
Offline Kevin K
Re: my engine build
« Reply #28 on: August 10, 2010, 11:20:15 PM »
ah thats what i though as well before vwchris informed me about this theory
aparently even if im 6-1 and my dads 5-9 hes still taller
1960 bug
Offline Kevin K
Re: my engine build
« Reply #29 on: September 11, 2010, 10:21:40 PM »
this is where i am on the rebuild
i was going to put on the rods, but  i need to clean them and it was late at night, i didn't want to make the house smell like solvent before every one went to bed
so ill do it tomorrow
any way so far so good it seems to be clearing every thing
it looks like it will clear the cam followers but again i need to clean them in solvent tomorrow
but hear are some pics
but unfortunatly you will need to be loged in to see them
« Last Edit: September 14, 2010, 03:16:11 PM by Kevin K »
1960 bug
