Author Topic: my engine build  (Read 29876 times)
Offline Kevin K
Re: my engine build
« Reply #30 on: September 11, 2010, 11:00:04 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #31 on: September 11, 2010, 11:02:56 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #32 on: September 11, 2010, 11:03:48 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #33 on: September 11, 2010, 11:42:34 PM »
« Last Edit: September 12, 2010, 09:23:50 AM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #34 on: September 13, 2010, 09:36:58 PM »
now I'm done putting on my rods on my crank and i also did the 1st test fit with every thing i the case and every thing is fitting nicely
all we have to do is put a shim or two under the cylinder then i can move on to the heads and getting them ready
1960 bug
Offline Kevin K
Re: my engine build
« Reply #35 on: September 13, 2010, 09:52:52 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #36 on: September 13, 2010, 09:53:31 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #37 on: September 13, 2010, 09:56:46 PM »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #38 on: September 13, 2010, 09:57:55 PM »
2
1960 bug
Offline Kevin K
Re: my engine build
« Reply #39 on: January 17, 2011, 05:30:50 PM »
i do not know why but u have to be logged in to see the pics
1960 bug
Re: my engine build
« Reply #40 on: January 17, 2011, 09:49:53 PM »
Kevin get it finished for a test and tune in Florence!
Gary
Offline Kevin K
Re: my engine build
« Reply #41 on: April 12, 2011, 09:08:24 PM »
sorry Gary
i suppose that i was a little to late for that test
as i have just finished porting my intake and exhaust ports
cutting the valve seats and replacing the exhaust valve guides
here are some pics
sorry again
i have not yet been able to post the pics so i put them on an attachment so you have to be logged in to see them
Kevin k
« Last Edit: April 12, 2011, 09:31:36 PM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #42 on: April 12, 2011, 09:26:29 PM »
it might not be pretty but it was my first time doing this stuff
« Last Edit: April 13, 2011, 03:11:30 PM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #43 on: April 12, 2011, 09:29:58 PM »
i also painted my block
 ;D
1960 bug
Offline Kevin K
Re: my engine build
« Reply #44 on: April 22, 2011, 10:46:40 PM »
i finished my long block just a few minutes ago
here are some pics
again
must be logged on to see them
sorry
1960 bug
Offline Kevin K
Re: my engine build
« Reply #45 on: April 22, 2011, 10:48:47 PM »
that is my dads valve grinder
it was his first time using it and it was pretty cool
« Last Edit: April 22, 2011, 10:51:48 PM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #46 on: April 22, 2011, 10:49:41 PM »
 :D
1960 bug
Re: my engine build
« Reply #47 on: April 23, 2011, 12:46:44 PM »
Did you remember the lower cylinder deflector tins?
Offline Kevin K
Re: my engine build
« Reply #48 on: April 23, 2011, 06:51:18 PM »
yes i did
but now i have the problem with my retainer bottoming out on the exhaust valve guide
me and my dad are going to sleep on it and look at it again in the morning
Kevin k
1960 bug
Re: my engine build
« Reply #49 on: April 24, 2011, 12:32:47 PM »
great work kevin!!! cool son & father project too!
Offline Kevin K
Re: my engine build
« Reply #50 on: April 24, 2011, 02:09:38 PM »
thanks
me and my dad have a lot of fun with it
 and just today we fixed the problem with the retainer bottoming out on the guide
it turns out that i had ratio rocker and we didn't even know it, that combined with the valve guides that we put into the head had a very high shoulder on the top was the problem
so i put stock rockers on it and it fixed the problem
1960 bug
Offline Kevin K
Re: my engine build
« Reply #51 on: May 17, 2011, 07:51:15 AM »
its still coming along
iv got almost all of my tin fitting good
i just have to get my front apron piece to fit with the header that I'm using
then it take it all apart and paint and put it all back together
1960 bug
Offline Kevin K
Re: my engine build
« Reply #52 on: May 17, 2011, 08:00:26 AM »
here are some pics
« Last Edit: May 18, 2011, 07:58:34 AM by Kevin K »
1960 bug
Offline Kevin K
Re: my engine build
« Reply #53 on: June 23, 2011, 10:05:54 PM »
i have finally finished my engine re-build after 2 years
its a 1914cc
with duel weber 42 dcnfs
engle 110 cam
counter waited crankshaft
stock heads ported
here is the link to the pics
http://s1231.photobucket.com/albums/ee520/volks5/finished%20engine/?albumview=slideshow
ps. I ROLLER PAINTED all of my tin
not bad eh?
« Last Edit: June 23, 2011, 10:09:53 PM by Kevin K »
1960 bug
Re: my engine build
« Reply #54 on: June 24, 2011, 12:16:55 AM »
 PDT_Armataz_01_37 Has it run yet?
Re: my engine build
« Reply #55 on: June 24, 2011, 04:26:47 PM »
not bad eh?
[/quote]
Great Job Kevin ! I'll Hire you to do the tin on my Rail!
Gary
Offline Kevin K
Re: my engine build
« Reply #56 on: June 24, 2011, 11:31:24 PM »
no it hasn't ran yet, I'm waiting on fittings for my oil filter and some oil hose.
but it is technically done right?
and that paint was one very long process and involved a lot of work
but worth it in the end.
1960 bug
Offline Kevin K
Re: my engine build
« Reply #57 on: July 03, 2011, 08:43:15 PM »
1960 bug
Re: my engine build
« Reply #58 on: July 03, 2011, 09:27:28 PM »
Offline GMB
Re: my engine build
« Reply #59 on: July 04, 2011, 12:32:43 PM »
From one engine builder to another "Great Job Kevin!"
Gary.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
