Author Topic: anyone have a hinge pin removal tool  (Read 2711 times)
« on: November 06, 2009, 10:38:32 AM »
Anyone on here have a hinge pin removal tool I could borrow/rent? Alternatively anyone have a method that works really well? Have about 8 to do.
Re: anyone have a hinge pin removal tool
« Reply #1 on: November 06, 2009, 10:41:29 AM »
Its called an Air Hammer. What are you doing them on? Do you care much about the paint? If you do be sure to mask it off and place the door on cardboard....
« Reply #2 on: November 06, 2009, 12:15:28 PM »
« Reply #3 on: November 06, 2009, 01:02:35 PM »
OH SNAP!!!!!!!!! Where did you find them doors?????
Offline surgerypending
« Reply #4 on: November 06, 2009, 02:34:09 PM »
Bring em out Chris....I'll give you a hand to get those out. Soak em in wd40 or liquid wrench first.
« Reply #5 on: November 06, 2009, 02:54:00 PM »
Quote from: kirin
works...but not always & can get pretty messy pretty quick if you're not carefull.
Quote from: surgerypending
skip the wd-40...it wont do much as a penetrating fluid...it's main use is for water-displacement (wd).
like gerry said...try liquid wrench...or pb blaster or rost off (wurth product). a little heat might help too (carefull not to burn that sweet og mango paint) and a couple sharp and quick "shocks" from a punch & hammer might help "free" it up.
pretty sure that the tool chris is talking about is the one in the link below. last i heard steve w. (beetleman here on the asf) might have one for rent/barter/borrow...? it's something i'll need to use pretty soon to for the pins on the 64!
http://www.thesamba.com/vw/classifieds/detail.php?id=522556
« Reply #6 on: November 06, 2009, 03:05:02 PM »
Yes, I was looking at that tool this morning. $180 is a lot though for how often I would use it personally. If no-one around here has one would a group of us want to go in on one. I would be happy to put in $50 if there were four of us OK with sharing it. We could rent it out to recoup some of the cost too.
Doors came from 58binz (Ross mullen) I was just going to look at stationary side window glass, and those were the doors they happened to be in 8)
« Last Edit: November 06, 2009, 03:06:39 PM by vwboop »
« Reply #7 on: November 06, 2009, 03:08:50 PM »
Thanks Gerry, but bus won't fit in the Dodge  ;D I may come out with just the doors though. Awesome.
« Reply #8 on: November 06, 2009, 03:59:42 PM »
The tool that Joey makes/sells is the cats ass! I borrowed one from a friend and I had the pins out of my the oval doors in under 10mins! Well worth every penny.
Offline number3
  • Rob Frose
    • http://www.avrparts.com
« Reply #9 on: November 06, 2009, 05:58:03 PM »
Chris,
I have that tool available to rent/barter/borrow.
I haven't used it on a bus but I was told it works just slick.  Beetle doors are no problem.
If you're coming through Abby anytime in the near future I can leave it at AVR for you. You can PM me for the particulars.
Rob
« Reply #10 on: November 06, 2009, 09:39:24 PM »
You are all aware that bus cargo door hinge pins are a smaller diameter than beetle or bus front doors and that they are split pins, right?
Chris give me a call in the AM.
