"gunk"?
Topic: "gunk"? (Read 4985 times)
James Buchan
"gunk"?
April 06, 2004, 05:08:06 PM »
So I pulled my rear window out today to clean it up and get ready for paint and I was suprised to find what looks like seam seal/old thick adhesive under the window seal. Is this normal? I thought it would be just the lip of the window sill. Or is it just due to the fact the PO put cal-look rubber in and couldn't get it to seal properly.
sourkraut
"gunk"?
April 06, 2004, 10:15:04 PM »
Sometimes a sealent is used just as a precaution depending on who did it and were it was done. It is fairly normal, is it still sticky or has it cured. If it is sticky I would think it is butyl and should clean off with tar remover or acrysol.
Und ich Idiot habe es gemacht.
James Buchan
"gunk"?
April 07, 2004, 12:01:43 AM »
Nope solid kinda like seam sealer.
sourkraut
"gunk"?
April 07, 2004, 10:26:13 PM »
If its solid I would think its urethane the same stuff we put windshields in with. It doesnt come of easy it has to be scraped and sanded.
James Buchan
"gunk"?
April 07, 2004, 10:54:00 PM »
Yes I've found that out
Where do you work Sour?
Last Edit: April 07, 2004, 10:54:23 PM by James Buchan
sourkraut
"gunk"?
April 07, 2004, 11:23:30 PM »
I work at Apple Auto Glass, Ive been there for a while now. All I do is auto glass all day long, we also do upholstery.
James Buchan
"gunk"?
April 08, 2004, 12:00:09 AM »
DO you have a line on polycarbonate? (lexan)
sourkraut
"gunk"?
Reply #7 on:
April 08, 2004, 12:28:32 PM »
Not realy we just get it all from Industrial plastics and paints on 64 /Mufford cres. How much did you need and what thickness. Ill check into it.
"gunk"?
