Author Topic: "gunk"?  (Read 4976 times)
"gunk"?
« on: April 06, 2004, 05:08:06 PM »
So I pulled my rear window out today to clean it up and get ready for paint and I was suprised to find what looks like seam seal/old thick adhesive under the window seal. Is this normal? I thought it would be just the lip of the window sill. Or is it just due to the fact the PO put cal-look rubber in and couldn't get it to seal properly.
Offline sourkraut
"gunk"?
« Reply #1 on: April 06, 2004, 10:15:04 PM »
Sometimes a sealent is used just as a precaution depending on who did it and were it was done. It is fairly normal, is it still sticky or has it cured. If it is sticky I would think it is butyl and should clean off with tar remover or acrysol.
Und ich Idiot habe es gemacht.
"gunk"?
« Reply #2 on: April 07, 2004, 12:01:43 AM »
Nope solid kinda like seam sealer.
Offline sourkraut
"gunk"?
« Reply #3 on: April 07, 2004, 10:26:13 PM »
If its solid I would think its urethane the same stuff we put windshields in with. It doesnt  come of easy it has to be scraped and sanded.
"gunk"?
« Reply #4 on: April 07, 2004, 10:54:00 PM »
Yes I've found that out :) Where do you work Sour?
« Last Edit: April 07, 2004, 10:54:23 PM by James Buchan »
Offline sourkraut
"gunk"?
« Reply #5 on: April 07, 2004, 11:23:30 PM »
I work at  Apple Auto Glass, Ive been there for a while now. All I do is auto glass all day long, we also do upholstery.
"gunk"?
« Reply #6 on: April 08, 2004, 12:00:09 AM »
DO you have a line on polycarbonate? (lexan)
Offline sourkraut
"gunk"?
« Reply #7 on: April 08, 2004, 12:28:32 PM »
Not realy we just get it all from Industrial plastics and paints on 64 /Mufford cres. How much did you need and what thickness. Ill check into it.
