Technical
Transmission Forum
FLEX BOWDEN TUBE FOR CLUTCH CABLE (BETWEEN TRANS & CHASSIS TUBE)
Topic: FLEX BOWDEN TUBE FOR CLUTCH CABLE (BETWEEN TRANS & CHASSIS TUBE) (Read 7875 times)
egspot
August 19, 2009, 12:00:01 PM »
What would be the effect if something sligthly pinched or altered the path of the flex bowder tube?
http://www.cardomain.com/ride/2142087
Bruce
Re: FLEX BOWDEN TUBE FOR CLUTCH CABLE (BETWEEN TRANS & CHASSIS TUBE)
August 19, 2009, 07:30:22 PM »
What are you seeing that you think is out of place?
egspot
August 19, 2009, 07:47:21 PM »
Installed something like this:
https://www.cip1.ca/ProductDetails.asp?ProductCode=C13%2D9550
PADDED TRANSMISSION STRAP KIT
C13-9550
The loop that straps to the left on the frame may be interfearing as it feels like a slipping clutch on 2-3 fast shift.
Does that make sence?
Bruce
August 20, 2009, 09:18:10 PM »
I thought your engine was dead?
If the bowden tube is routed over half an inch, nothing unusual will happen.
egspot
August 20, 2009, 09:40:44 PM »
Fixed.
I will look into the flex tube this week end.
Bruce
August 20, 2009, 09:50:51 PM »
What happened to the engine?
egspot
August 20, 2009, 10:59:40 PM »
Quote from: Bruce on August 20, 2009, 09:50:51 PM
Rod bushing.
Technical
Transmission Forum
