Author Topic: FLEX BOWDEN TUBE FOR CLUTCH CABLE (BETWEEN TRANS & CHASSIS TUBE)  (Read 7876 times)
What would be the effect if something sligthly pinched or altered the path of the flex bowder tube? ???
Re: FLEX BOWDEN TUBE FOR CLUTCH CABLE (BETWEEN TRANS & CHASSIS TUBE)
« Reply #1 on: August 19, 2009, 07:30:22 PM »
What are you seeing that you think is out of place?
« Reply #2 on: August 19, 2009, 07:47:21 PM »
Installed something like this:
https://www.cip1.ca/ProductDetails.asp?ProductCode=C13%2D9550
PADDED TRANSMISSION STRAP KIT
C13-9550
The loop that straps to the left on the frame may be interfearing as it feels like a slipping clutch on 2-3 fast shift.
Does that make sence?
« Reply #3 on: August 20, 2009, 09:18:10 PM »
I thought your engine was dead?
If the bowden tube is routed over half an inch, nothing unusual will happen.
« Reply #4 on: August 20, 2009, 09:40:44 PM »
Fixed.
I will look into the flex tube this week end.
« Reply #5 on: August 20, 2009, 09:50:51 PM »
What happened to the engine?
« Reply #6 on: August 20, 2009, 10:59:40 PM »
Rod bushing.
