Author Topic: 200HP=$$$$$$  (Read 7301 times)
Offline Scooby
200HP=$$$$$$
« on: July 23, 2009, 09:49:20 PM »
Starting to think about my next project.So it's time to start hunting for parts.One of the goals for the car is to have 200HP.And since I have never built a big hp motor.I am a bit in the dark about the cost of it.It's going to be a summer only car.Would like it to cruise down the hiway with no problems,and maybe a few trips down the strip.So if anyone has built at big motor I would love to hear your ideas,thoughts and prices.And if a aircooled motor is going to be too expensive,then I might look at other ideas!!!!And as for the tranny,one thing at a time.Thanks guys,Scooby
Re: 200HP=$$$$$$
« Reply #1 on: July 24, 2009, 10:07:22 PM »
building a big motor takes skill and knowledge they just don't bolt together ,those days are way over . cost 10k -15k if you have nothing .there is more than the motor to think about .like cooling ,fuel system ,ignition, transmission etc .if you have never ran a high strung motor on the street they require alot of maintance , adjusting and great tuning skill .and usally don't have a real long life span .
i would suggest building a 78/90.5 with a solid bottom end and spray it with 50-100 shot of nitrous at the track .way easier to build , less expence and the motor will still make tons of streetable power and run great on the streets and highway and be a animal at the track .
good luck .and start hunting for those parts . great canadian swap meet is a great place to start
Re: 200HP=$$$$$$
« Reply #2 on: July 24, 2009, 11:12:55 PM »
That is as traight scoop as you can get.
You can probably build a 1915-2165 with 100 to 120 + hp  for less but, it is only as good as the weakest link and you measure that by $$$ and time.
my two bits
Offline Scooby
Re: 200HP=$$$$$$
« Reply #3 on: July 25, 2009, 08:38:43 AM »
Thanks for the great info Jim.That's what I wanted to hear from someone that has built,and run a big motor.I would love to pick your brain a little more at the great Canadian.
Re: 200HP=$$$$$$
« Reply #4 on: July 25, 2009, 11:16:07 AM »
If you think you're gonna build the engine first and run it for a while with a stock gearbox, it will work...... for a very short while.
It's possible to build a 200hp NA pump gas engine using off-the-shelf parts.
84x94
CB Wedgeport 44x37 heads
Web 86C with 1.4 rockers
10:1 CR
Weber 48 IDAs
1.75" header
Re: 200HP=$$$$$$
« Reply #5 on: July 25, 2009, 08:13:05 PM »
BRING COLD BEER
Re: 200HP=$$$$$$
« Reply #6 on: July 25, 2009, 09:28:00 PM »
BRING COLD BEER
lmmfao!!!  good call jim!! ;D 8)
