Author Topic: noise from engine  (Read 7219 times)
noise from engine
« on: July 14, 2009, 06:40:35 PM »
So after the trip to Seymour park I have detected a noise which I believe is a exhaust leak. I cheked the valves and they are where they should be .006. i would like a second opinion on the noise.
If it is the exhaust I have another that i need to intall a sensor on before I use it.
Anyone available to listen to this?
Offline Chris W
  • Portland Oregon
Re: noise from engine
« Reply #1 on: July 14, 2009, 10:11:43 PM »
Cover the exhaust pipe and see if the engine dies, that will tell you if its a big exhaust leak.
« Reply #2 on: July 14, 2009, 10:18:25 PM »
thanks Chris. will try that tomorrow.
« Reply #3 on: July 15, 2009, 08:37:26 PM »
Tried it and got it around 4k rpms did not shut down.
Offline Chris W
  • Portland Oregon
« Reply #4 on: July 15, 2009, 09:06:07 PM »
It should die at idle with your hand or foot over the pipe. Sounds like a exhaust leak.
« Reply #5 on: July 15, 2009, 09:26:00 PM »
Thanks Chris.
« Reply #6 on: July 16, 2009, 09:02:56 PM »
available ? every morning you drive by and wake my kids .yes its your exhaust , please fix it or get a new route .if you need something welded on a new pipe i will be happy to do it.
« Reply #7 on: July 16, 2009, 09:13:36 PM »
Thanks Jim.
I am meetting GMB this week end. Hope it is a simple fix.
Thanks to all who offered their help.
« Reply #8 on: July 17, 2009, 02:40:00 PM »
I went under and realized the bolt comming out of the top right head #1 exhaust to the heater is twice as long as the bottom one and a bitch to poke at it. I either need a special wrench or there is a special way to get to it because i have not been able to move it yet.
Would this make the engine sound like a 22 machine gun at 3000 rpms?
« Reply #9 on: July 19, 2009, 06:07:08 PM »
Fixed that.
I was wrong:\I went downstairs at 10:00 am  and worked until 5:00. I could not get to the stud and ended up taking the heaters off. got one of the metal plates off and bent the other. I installed the merger and  was trying to get it going for Wednesday. Developed a small oil leak under the tubes and when I started it the noise remains so my whole theory was blown away.
« Reply #10 on: July 20, 2009, 06:17:27 PM »
Time to go with Alan's diagnosis.
« Reply #11 on: July 20, 2009, 06:47:44 PM »
yup....
I am thinking a streched valve or a burned one on the #1 exhaust. The stud was loose and I think that would contributed.
There was no metal particles when I changed the oil for the second to in the last 1500 miles/ 4 months.
« Reply #12 on: August 01, 2009, 02:40:58 PM »
Alan was correct.
I was wrong...again,
« Reply #13 on: August 01, 2009, 11:07:18 PM »
Alan was correct.
so what exactly was it?
i hope you get it sorted quickly and get back up & rolling!
« Reply #14 on: August 02, 2009, 09:40:46 AM »
Rod bushing?
