Author Topic: Vw 003 Automatic trans band adjustment  (Read 7318 times)
Offline vwguy
« on: July 07, 2009, 08:34:36 AM »
Hey Guy,s ,I am rebuilding a Vw 003 Auto trans, and I need the values for the two band adjustments.Can anyone help.
  Regards   Jim
Offline boxacr
  • Junior Member
Re: Vw 003 Automatic trans band adjustment
« Reply #1 on: January 21, 2010, 05:40:24 AM »
Have you had a chance to look at Bently. I seem to remember a torque of less or around 20'#. Arrived at in three stages for both.
Hope This Helps.
Eric
« Reply #2 on: January 21, 2010, 11:49:15 PM »
Somewhere I have some NOS discs for the forward clutch.  If yours are needing replacement.....
Offline Trevor P
« Reply #3 on: January 30, 2010, 09:35:30 AM »
As per the VW shop manual:
Tighten  front (2nd gear) band screw to 1 mkg (88 in/lbs) to settle the band, then loosen screw and tighten again to 0.5mkg (44 in/lbs). From this position turn the screw out 1 3/4 - 2 turns and tighten locknut.
Tighten rear (1st gear) band screw same as above then turn screw out 3 1/4-3 1/2 turns and lock it.
« Last Edit: January 30, 2010, 09:39:09 AM by Trevor P »
'53 Barndoor single cab
'70 911T
Offline vwguy
« Reply #4 on: February 02, 2010, 08:56:58 AM »
Thanks guy,s its done ;D
  Jimmy D
