Technical
Transmission Forum
Vw 003 Automatic trans band adjustment
Topic: Vw 003 Automatic trans band adjustment (Read 7314 times)
vwguy
July 07, 2009, 08:34:36 AM »
Hey Guy,s ,I am rebuilding a Vw 003 Auto trans, and I need the values for the two band adjustments.Can anyone help.
Regards Jim
boxacr
Junior Member
Re: Vw 003 Automatic trans band adjustment
January 21, 2010, 05:40:24 AM »
Have you had a chance to look at Bently. I seem to remember a torque of less or around 20'#. Arrived at in three stages for both.
Hope This Helps.
Eric
Bruce
January 21, 2010, 11:49:15 PM »
Somewhere I have some NOS discs for the forward clutch. If yours are needing replacement.....
Trevor P
January 30, 2010, 09:35:30 AM »
As per the VW shop manual:
Tighten front (2nd gear) band screw to 1 mkg (88 in/lbs) to settle the band, then loosen screw and tighten again to 0.5mkg (44 in/lbs). From this position turn the screw out 1 3/4 - 2 turns and tighten locknut.
Tighten rear (1st gear) band screw same as above then turn screw out 3 1/4-3 1/2 turns and lock it.
Last Edit: January 30, 2010, 09:39:09 AM by Trevor P
vwguy
February 02, 2010, 08:56:58 AM »
Thanks guy,s its done
Jimmy D
Technical
Transmission Forum
