Author Topic: points  (Read 6685 times)
points
« on: September 11, 2008, 08:37:08 PM »
has anyone picked up any two peice points made by bosch in like the last 4 months? ive bought two and keep going back to my damn old set, cause the fiber stick that rides on the loabs broke off, and the newest one was made from plastic wore out in like 700-1000 miles, just curious if perhaps its the distributor thats causing this or anyone else have problems with this.
sorry this is just to funny  O0
Offline jefftrish
Re: points
« Reply #1 on: September 11, 2008, 10:05:47 PM »
Are you putting lube between the metal shaft and plastic lobe?
Re: points
« Reply #2 on: September 12, 2008, 06:59:06 AM »
yeah it was some kinda machine lube stuff kinda sorta like white grease...
Re: points
« Reply #3 on: September 13, 2008, 11:54:00 PM »
...a small dab of wheel bearing grease has always worked well for me.
not sure about your lobe problem tho...allthough they're bosch and i've never had an issue with them...where are you getting these parts from?
Re: points
« Reply #4 on: September 14, 2008, 09:09:11 AM »
Yeah ive had 010 and 019 using im sure the same points, and never had a wear or brake on them i was just seeing if perhaps there was a bad batch going around like the old engle cams, ive been getting them at cip
Offline Glenn
    • http://www.glenn-ring.com
Re: points
« Reply #5 on: November 19, 2008, 05:12:44 AM »
Use Bosch "Distributor Grease" and not white lube or bearing grease. My last set of points were in for 17,000 miles and I replaced them just for the hell of it.
Get the the Bosch 01016 over the 01001. It has a stronger springs.
Glenn
74 Beetle Specs web page
74 Beetle Resto web pages
Re: points
« Reply #6 on: November 24, 2008, 09:22:27 PM »
ive never seen distributor grease before, cool!
Offline Glenn
Re: points
« Reply #7 on: December 02, 2008, 12:04:23 PM »
Glenn
Re: points
« Reply #8 on: December 02, 2008, 05:33:55 PM »
hahahaha now i have!
Offline Glenn
Re: points
« Reply #9 on: December 03, 2008, 04:45:25 PM »
It resists high heat and is really sticky. It's great on the tranny input shaft also.
Glenn
